%3CLINGO-SUB%20id%3D%22lingo-sub-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ESupport%20script%20drag-and-drop%20between%20tables%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWhat%20inspired%20this%20wish%20list%20request%3F%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3EI%20often%20find%20myself%20with%20new%20data%20tables%20that%20are%20almost%20identical%20to%20old%20ones.%26nbsp%3B%20I%20need%20to%20pull%20the%20plotting%20scripts%20from%20the%20old%20tables%20into%20the%20new%20ones.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhat%20is%20the%20improvement%20you%20would%20like%20to%20see%3F%26nbsp%3B%26nbsp%3B%3C%2FSTRONG%3EWhen%20I%20drag%20a%20script%20from%20the%20top-left%20pane%20of%20a%20data%20table%20window%20to%20another%20window%2C%20it%20looks%20like%20it's%20accepting%20it%2C%20but%20then%20nothing%20happens.%26nbsp%3B%20I%20would%20like%20to%20be%20able%20to%20copy%20a%20bunch%20of%20scripts%20from%20one%20data%20table%20into%20another%20via%26nbsp%3Bdrag-and-drop.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhy%20is%20this%20idea%20important%3F%26nbsp%3B%3C%2FSTRONG%3E%26nbsp%3B%20The%20script%20drag-and-drop%20is%20an%20intuitive%20action%20that%20seems%20to%20work%2C%20and%20it's%20frustrating%20that%20it%20doesn't.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E(JMP%20v17%2C%20Windows%20and%20Mac)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-680137%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EData%20Access%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EData%20Blending%20and%20Cleanup%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Support%20script%20drag-and-drop%20between%20tables%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680260%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3Ethat'%20right%20-%20it's%20almost%20doing%20what%20the%20user%20expects%20and%20then%3A%20no%20script%20shows%20up%20in%20the%20list%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3Eworkaround%3A%20use%20copy%20%26amp%3B%20paste%20from%20the%20right%20click%20context%20menu.%20It%20also%20works%20if%20more%20scripts%20are%20selected%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3Eeaster%20egg%3C%2FSTRONG%3E%3A%20copy%20the%20code%20of%20a%20script%20(i.e.%3A%20not%20the%20%3CEM%3Escript%3C%2FEM%3E)%20and%20click%20on%20paste%20in%20the%20right%20click%20menu.%3C%2FP%3E%3CP%3EThis%20runs%20the%20script%20for%20the%20target%20table.%3C%2FP%3E%3CP%3EAlso%20cool%20for%20Report%2FSave%20Script%20to%20Clipboard%20-%26gt%3B%20run%20it%20for%20another%20table%3C%2FP%3E%3C%2FLINGO-BODY%3E
Support script drag-and-drop between tables
What inspired this wish list request?  I often find myself with new data tables that are almost identical to old ones.  I need to pull the plotting scripts from the old tables into the new ones.
What is the improvement you would like to see?  When I drag a script from the top-left pane of a data table window to another window, it looks like it's accepting it, but then nothing happens.  I would like to be able to copy a bunch of scripts from one data table into another via drag-and-drop.
Why is this idea important?   The script drag-and-drop is an intuitive action that seems to work, and it's frustrating that it doesn't.
(JMP v17, Windows and Mac)
1 Comment
hogi
Level XII
that' right - it's almost doing what the user expects and then: no script shows up in the list
workaround: use copy & paste from the right click context menu. It also works if more scripts are selected
easter egg: copy the code of a script (i.e.: not the script) and click on paste in the right click menu.
This runs the script for the target table.
Also cool for Report/Save Script to Clipboard -> run it for another table
