Single Sampling by Attributes
Single attributes sampling plans or MIL-STD-105E are used when the inspections can only be classified as two outcomes. One can think of this type of plan as go / no-go or in specification ...
stan_koprowskiSingle attributes sampling plans or MIL-STD-105E are used when the inspections can only be classified as two outcomes. One can think of this type of plan as go / no-go or in specification ...
stan_koprowskiRecently I gave an internal JMP talk on Python Tips and Tricks. There's one tip in particular that I think is powerful, so I'd like to share it with you: creating a JSL function that wraps the call t...
Paul_NelsonOdds ratios in a logistic regression model are used to interpret the effect of the factors included in the model. Logistic regression models are widely used throughout industry and academia. They a...
Duane_HayesThe 2024 NFL draft begins Thursday, April 25, and will be full of intrigue for NFL fans. For teams near the bottom of the standing, the draft represents hope for the future. The right player can turn...
Peter_Hersh新バージョン「JMP 18」には、以前搭載されていたサンプルデータ「Boston Housing.jmp」が含まれていません。このサンプルデータは、多変量データの可視化や予測モデルの構築方法を説明するのに便利でしたが、差別的、非倫理的、不公平な内容が含まれているため除外されました。 参考 JMP® sample data table "Boston Housing.jm...
Masukawa_NaoTo predict the reliability of some parts or products, the time and resources required to test under normal conditions isn’t practical, because it could take years for a failure to occur. Instead, eng...
gail_massariJMPジャパン事業部では、今年3月から4月にかけて「JMP情報局」というセミナーを毎週火曜日、全8回で実施しました。このセミナーは、毎回30分という短時間でJMPの様々な情報をお伝えすることを目的としており、想定を上回る多くの方々にご参加いただきました。 エンディングで頂いた多くのリアクション 本ブログでは、4月に実施した第5回~第8回で実施...
Masukawa_NaoThe Functional Data Explorer (FDE) in JMP Pro is generally used when the output of a process is functional/curved data. However, with a few tricks, functional data can also be used as an inp...
Jed_CampbellWelcome back to Analytics with Confidence. In this series, I am exploring the key to success with modern data analytics: validation. In the first and second posts we discussed general...
Phil_KayProcess analytical technology (PAT) is not new to the world, but it may be a newer concept for many, especially when it comes to using JMP to analyze and process PAT data. PAT can be part of and is o...
Bill_WorleyEnhance your regression analysis with the powerful combination of robust techniques and JMP 18, now featuring seamless integration with Python. Simple Case Study Here's a sample...
DaeYun_KimJMP 18 has a new way to integrate with Python. The JMP 18 installation comes with an independent Python environment designed to be used with JMP. In addition, JMP now has a native Python editor and P...
SamGardnerOne year ago, JMP users who also used Python made it clear they thought our Python interface was less than optimal. Ouch! We thought the JMP and Python integration we introduced more than five years ...
gail_massariA bioassay is an analytical method to determine concentration or potency of a substance by its effect on living cells or tissues. Bioassays are used to estimate the potency of agents by observing the...
Valerie_NedbalHey there! You may remember me from my previous stint with JMP Statistical Discovery when I was a member of the Life Sciences group. Well, I’m back, and things are better than ever! Yes, they are. ...
Richard_ZinkHave you ever been tasked with predicting who will cancel their services with your company? Or which patients will discontinue their medication? Or perhaps which individuals will be the early adopter...
KristenBradfordJMP Clinical was released 11 years ago specifically for the analysis and review of ongoing clinical trials centered on standardized and structured data. The intent was that a reviewer would receive d...
Chris_KirchbergFor previous Need for Speed posts, click here! My name is 2-Click Clovis, and I am truly passionate about data analysis and, most important, time efficiency! JMP was an integral ...
cweisbartJMP 18 brings powerful new capabilities in its Python integration, including: An embedded version of Python 3.11. Package installation support. Python-aware script editor that can run p...
Paul_NelsonI'm not sure what the point of this training exercise was, but I did learn Bob's name. There were a bunch of us in a large room and we were each assigned a friend and a foe (secretly, no sha...
Craige_Hales
