Level XIII
Tips and Tricks - best practice with JMP/JSL
There is a wonderful blog post by @Craige_Hales : How Do You Draw a Circle?
It nicely illustrates that there are multiple solutions to every problem - with varying degrees of success in achieving the goal and in investing ressources.
And often there is not the ONE solution with maximum points in all categories:
  • goal was met
  • length of code
  • speed (to write the code)
  • speed (to execute the code)
  • complexity (to understand the code)
  • complexity ( to remember the code)
Examples:
<td, width="25%">links
topic standard approach faster/optimized approaches
General
learn scripting trial and error watch the recordings of theJSL Scripters Club Meetings
Data import
open multiple data files use open()  (inside a for loop) use MFI
(faster csv reader!)
Open multiple Files
get a list of files generate the file list - via Python, command prompt etc. and paste it into a new JMP table MFI
→ right click on file list → Make into data table
find a file in a deep/complicated network tree structure use MFI or Windows File dialog create a wrapper for Python/GLOB
Data tables
change column entries step by step via for loop data table subscripting Data table subscripting
 dt << begin/end data update;
before/after the loop
Very slow loop behaviour
add columns to a data table merge data tables via Tables/Update first aggregate via Tables/Summary
then merge via Tables/Update
Speed up Tables/Update
column aggregation
with restrictions
with a character comparison Col(if(... gets very (!!!) slow:
col Max( if(:sex=="M", ...)
a) use if(:sex==1,...)
How-do-I-use-the-Col-Maximum-Formula-with-a-where
(fixed in V19)
b) replace :sex=="M"
with contains(:sex,"M")
 count words e.g. count xxx in :col:
N Rows(loc(Words(:col),"xxx"))
(Length(:col)-
Length(Substitute(:col, "xxx", ""))
)/3​
Count number of occurrences of specific words in a string
rank unique
New Column( "rank_unique",
Formula( Col Minimum(
Col Rank( If(
Row() == Col Min( Row(),
:age, :sex ), 1 ), :age ),
:age,:sex))
Col Score(:age, :sex)
(v19)
Add dense ranking to Ranking Tie and Col Rank functions
can be very slow in combination with other options
apply the option in a second step
Recode - Parse as Number
replace values with other values for loop or Recode use DataTable subscripting Replace missing values with 0
Should you Loop through a data table or use Recode, or use Get Rows Where to change values in a data...
select rows based on a formula If dt << select where() is too slow
... split it into 2 steps:
myrows= dt << get rows where();
dt << select rows(myrows)
Formula to check if any of a list of items is contained in the rows of a column
spec calcualations some manual JSL code support this wish with a Kudo:  :folded_hands: is in spec (value)
Graphs
Reports
Export
Database access
Neural Networks
[More Topic Containers like this]
Level XIII
Re: Speeding up JMP/JSL
-> Table moved to main post.
It depends a lot on what you are doing. Some good general tips can be found from Scripting Guide > Efficient Scripts
Level XIII
Thanks, a good place to start ...
Going further, how about a list with as many entries as possible along the idea:
If you want to do this, you probably thought of this approach - but concerning speed, the other approach is much better!
Who is interested in sharing his secrets :)
Level XIII
Level XIII
I added a cool trick to count words by @ian_jmp :
Level XIII
Level XIII
Wonderful talk on XPath & Subscripting in Reports:
 https://community.jmp.com/t5/Abstracts/I-Can-See-It-How-Do-I-Get-It/ev-p/776041
Level XIII
JM 19:
column aggregation
with restrictions
(fixed in V19)
rank unique
Col Rank( If(
:age,:sex))
(v19)
