See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Tips and Tricks - best practice with JMP/JSL
Level XII
There is a wonderful blog post by @Craige_Hales : How Do You Draw a Circle?
It nicely illustrates that there are multiple solutions to every problem - with varying degrees of success in achieving the goal and in investing ressources.
And often there is not the ONE solution with maximum points in all categories:
  • goal was met
  • length of code
  • speed (to write the code)
  • speed (to execute the code)
  • complexity (to understand the code)
  • complexity ( to remember the code)
Examples:
topicstandard approachfaster approacheslinks
General
learn scriptingtrial and errorwatch the recordings of theJSL Scripters Club Meetings
Data import
open multiple data filesuse open()  (inside a for loop)use MFI
(faster csv reader!)
Open multiple Files
get a list of filesgenerate the file list - via Python, command prompt etc. and paste it into a new JMP tableMFI
→ right click on file list → Make into data table
find a file in a deep/complicated network tree structureuse MFI or Windows File dialogcreate a wrapper for Python/GLOB
Data tables
change column entriesstep by step via for loopdata table subscriptingData table subscripting
 dt << begin/end data update;
before/after the loop
Very slow loop behaviour
add columns to a data tablemerge data tables via Tables/Updatefirst aggregate via Tables/Summary
then merge via Tables/Update
Speed up Tables/Update
column aggregation
with restrictions (1)
the new approach via  Where (JMP18)
col Max(:weight,
:sex, where(:age==13))
is easy to remember, but very slow
doesn't work yet.
use the old approach via If:
col Max(if(:age=13,:weight,.),
:sex)
It looks more complicated but it's orders of magnitude faster *)
Col-Median-and-others:Where option
column aggregation
with restrictions (2)
*) unfortunately, with a character comparison Col... gets very (!!!) slow:
col Max( if(:sex=="M", ...)
->use if(:sex2==1,...)
How-do-I-use-the-Col-Maximum-Formula-with-a-where
replace :sex=="M"with contains(:sex,"M")
 count wordse.g. count xxx in :col:
N Rows(loc(Words(:col),"xxx"))
(Length(:col)-
Length(Substitute(:col, "xxx", ""))
)/3
Count number of occurrences of specific words in a string
rank unique
New Column( "rank_unique",
Formula( Col Minimum(
Col Rank( If(
Row() == Col Min( Row(),
:age, :sex ), 1 ), :age ),
:age,:sex))
support this wish with a Kudo:
Add dense ranking to Ranking Tie and Col Rank functions
can be very slow in combination with other options
apply the option in a second step
Recode - Parse as Number
replace values with other valuesfor loop or Recodeuse DataTable subscriptingReplace missing values with 0
Should you Loop through a data table or use Recode, or use Get Rows Where to change values in a data...
select rows based on a formulaIf dt << select where() is too slow
... split it into 2 steps:
myrows= dt << get rows where();
dt << select rows(myrows)
Formula to check if any of a list of items is contained in the rows of a column
spec calcualationssome manual JSL codesupport this wish with a Kudo: 🙏 is in spec (value)
Graphs
Reports
Export
Database access
Neural Networks
[More Topic Containers like this]
Level XII
Re: Speeding up JMP/JSL
-> Table moved to main post.
It depends a lot on what you are doing. Some good general tips can be found from Scripting Guide > Efficient Scripts
Level XII
Thanks, a good place to start ...
Going further, how about a list with as many entries as possible along the idea:
If you want to do this, you probably thought of this approach - but concerning speed, the other approach is much better!
Who is interested in sharing his secrets
Level XII
Level XII
I added a cool trick to count words by @ian_jmp :
Level XII
Level XII
Wonderful talk on XPath & Subscripting in Reports:
 https://community.jmp.com/t5/Abstracts/I-Can-See-It-How-Do-I-Get-It/ev-p/776041
