in the Scripting Index, there is a button "see also" which suggests the interested user alternative functions in the context of an initial found function.
Unfortunalely, there are some "links" missing between the entries. e.g.
get <-> set clipboard
N Args <-> Head
I posted a "container" wish to collect such missing links such that they can be added:
Scripting Index and online Help: "see also"
Did it happen to you as well that you search a function in the Scripting Index for some while and found out that you cannot find the right term to search it?
If you found the correct function afterwards by luck, could you please add a screenshot to the "container" wish to help other users to find the function faster ...
... and support the idea with a Kudo : )
