MTOF
new column with initial data values
Hi
Does anyone know how to script the creation of a new column with initial data values?
Below is my best guess, but it doesn't work. Cannot find any help on "initial data values" in the scripting guide.
BR, Marianne
dt=current data table();
dt<<new column("Selected", character, initial data values(constant("YES")));
pmroz
You're close.  This will work:
dt << new column("Selected", character, << set each value("YES"));
6 REPLIES 6
pmroz
MTOF
Excellent, just what I needed
JMP_Learner
Re: new column with initial data values
Hi!
I have a similar but a little more complicated problem:
The initial value I try to set is a function of loop index.
Suppose I have 50 files to open. When open each file, I want to add a new column, and fill the new column with the file name of this file. The initial value is supposed to be a constant. But, when this function is used within a loop, the code seems stuck. It opens the first file, without filling the initial value, and stopped.
How should I make it work?
Thanks a lot.
ian_jmp
Level X
Maybe something like this?
NamesDefaultToHere(1);
// Make some tables, save and close them, but keep a list
n = 4;
fList = {};
for(t=1, t<=n, t++,
	fName = "Table "||Char(t)||".jmp";
	dt = NewTable(fName, NewColumn("Data", Formula(RandomInteger(10))));
	dt << AddRows(20);
	InsertInto(fList, fName);
	Close(dt, Save("$DESKTOP/"||fName));
// Open the tables in the list and add the column
for(t=1, t<=NItems(fList), t++,
	fName = fList[t];
	dt = Open("$DESKTOP/"||fName);
	colVals = {};
	for(r=1, r<=NRow(dt), r++,
		InsertInto(colVals, fName);
	dt << NewColumn("File Name", Character, Values(colVals));
	DeleteFile("$DESKTOP/"||fName);
JMP_Learner
Ian_jmp:
Your idea works great! Thank you so much!
JMP_Learner
hogi
Level XIII
