JMPer Cable
Latest Posts
  • Double your fun with double forest plots!
    We explore Happy Little Forests, a happy little JMP add-in for producing many types of forest plots.
    Richard_Zink Richard_Zink
    JMPer Cable |
    Jan 29, 2026 11:31 AM
    118 views | 0 replies
  • Screening for safety signals among recurrent adverse events with the max difference plot
    I introduce the max difference plot as a more useful alternative to the tendril plot when screening for notable safety signals among recurrent adverse events.
    JMPer Cable |
    Jan 22, 2026 7:00 AM
    145 views | 0 replies
  • To data connector or to not data connector, that is the question.
    Is a data connector always necessary? Data connectors are an exciting addition to JMP, but they are not always necessary in every instance. This article discusses each data connector type within the new data connector framework to help you determine the best method for accessing your data.
    Dahlia_Watkins Dahlia_Watkins
    JMPer Cable |
    Jan 16, 2026 5:24 PM
    121 views | 0 replies
    No supplied image
  • JMP Live tips and tricks
    Here are some ideas to help you get the most out of JMP Live.
    John_Powell_JMP John_Powell_JMP
    JMPer Cable |
    Dec 18, 2025 10:16 AM
    6365 views | 0 replies
  • Column Switchers in JMP Live
    JMP Live makes Column Switchers Interactive on the Web.
    JMPer Cable |
    Dec 17, 2025 3:46 PM
    6863 views | 0 replies
  • Introducing the Patient Pareto plot
    We explore an extension to the classic Pareto plot.
    JMPer Cable |
    Nov 13, 2025 7:00 AM
    453 views | 0 replies
  • Utilizing the Custom Floorplan Heat Maps extension in conjunction with Environmental Monitoring
    The Custom Floorplan Heatmaps extension enables users to visualize environmental monitoring data at each time point for an entire floorplan.
    David_Elsheimer David_Elsheimer
    JMPer Cable |
    Nov 12, 2025 7:00 AM
    486 views | 1 replies
  • Dynamically explore time-to-event outcomes using the Survival Explorer add-in
    The Survival Explorer add-in produces a dynamically updating Kaplan-Meier plot with an accompanying number at risk table.
    JMPer Cable |
    Nov 11, 2025 6:56 AM
    431 views | 0 replies
  • Using dates, times, datetimes and durations in JMP
    There are four common time-based values that you might have to deal with in JMP: dates, times, datetimes and durations.
    Jeff_Perkinson Jeff_Perkinson
    JMPer Cable |
    Oct 28, 2025 8:26 AM
    49970 views | 1 replies
  • New in JMP Clinical 19
    The latest release of JMP Clinical makes it the most sophisticated visualization and analysis tool for clinical trials the market. It has as much to do with our teams that build the software as it does its amazing functionality. Building on the powerful functionality of JMP Pro, JMP has delivered a solution that addresses the needs of a wide audience, including safety surveillance teams, medical m...
    geoffrey_mann geoffrey_mann
    JMPer Cable |
    Oct 14, 2025 7:34 AM
    2626 views | 1 replies
  • Understanding simple mediation analysis in JMP Pro
    When two variables are related, the natural next question is “why?” Mediation analysis helps answer that by testing whether a third variable, the mediator, explains how the predictor influences the outcome. It moves us from “X is related to Y” to “X affects Y by changing M.” For example, in education research, we might find that students who feel a strong sense of belonging are more interested in ...
    Hamid_Sanei Hamid_Sanei
    JMPer Cable |
    Oct 9, 2025 6:00 AM
    666 views | 0 replies
  • See the latest in the JMP Marketplace
    JMP Marketplace is an online platform to help you extend JMP as your needs evolve. Like other app stores, JMP Marketplace offers a curated selection of fully tested applications, add-ins, data connectors, and other extensions that enhance and expand JMP’s powerful capabilities.   Watch a demo of the Marketplace here.
    kristen-slappey kristen-slappey
    JMPer Cable |
    Sep 12, 2025 9:36 AM
    2145 views | 0 replies
    No supplied image
  • Choosing estimators in the Causal Treatment platform
    When treatment is binary, the Causal Treatment personality in JMP enables you to choose between four estimation techniques: inverse probability weighting with ratio adjustment (IPWR), regression adjustment (REGADJ), augmented inverse probability weighting (AIPW), and propensity score matching. You may be comfortable with one of these estimation methods, or you may have no idea where to begin. Alon...
    MeichenDong MeichenDong
    JMPer Cable |
    Sep 12, 2025 9:31 AM
    2431 views | 0 replies
    No supplied image
  • From correlation to causation: The Causal Treatment platform
    Randomized controlled trials (RCTs) and other carefully designed statistical experiments are the gold standard for answering questions about cause and effect. Randomly assigning experimental units (for example, participants in a clinical trial) to treatment and control groups balances the two groups so as to minimize the chance of substantive differences between them other than those caused by any...
    JMPer Cable |
    Sep 12, 2025 9:30 AM
    2634 views | 0 replies
  • JMP 19: What's new in data connectors
    Data access is fundamental to JMP. For the last several releases, we've been building infrastructure so that you can access data efficiently, regardless of where it lives. Once you to get the data you need into JMP, you can begin answering the questions you have. Every version of JMP adds new efficiency gains, performance improvements, and workflow additions. JMP 19 continues that trend.
    Prefer vi...
    willmorgan willmorgan
    JMPer Cable |
    Sep 12, 2025 9:20 AM
    3556 views | 0 replies
  • New in Graph Builder for JMP 19
    JMP 19 brings many improvements for Graph Builder. Here are a few of the most significant additions. Constrained smoothers The smoother element has a new method called P-Spline. It’s a cubic spline, just like the existing Spline method, but it’s parameterized in a way that better supports constraints. Monotonic trend curves are the most requested smoother feature, and now it’s possible – and then ...
    XanGregg XanGregg
    JMPer Cable |
    Sep 12, 2025 9:09 AM
    3985 views | 11 replies
  • What’s new in JMP DOE
    JMP’s latest release brings a fresh wave of updates to the Design of Experiments (DOE) platform, with new tools and smarter workflows that make it easier to design, simulate, and explore experiments. Whether you're screening factors, simulating responses, planning sample sizes, or trying to pinpoint the root cause of a failure, there’s something new to try out. Smarter fault localization with Baye...
    Ryan_Lekivetz Ryan_Lekivetz
    JMPer Cable |
    Sep 12, 2025 9:08 AM
    2696 views | 1 replies
  • Organizing and filtering data in the JMP 19 data table
    Data tables come in many sizes. Occasionally, I work with a table that is small enough to fit on screen: no scrolling necessary and everything I need, I can see. Most of the time, however, my data tables are tall, wide, complex, and multifaceted. For tables like these, the new data table organization and filtering tools in JMP shine. Let’s explore some real data to see why. I’ve been a longtime fa...
    julian julian
    JMPer Cable |
    Sep 12, 2025 9:06 AM
    3686 views | 4 replies
  • Going further with Python in JMP 19
    JMP’s latest release builds on the Python integration support that was introduced in JMP 18 by focusing on a fundamental part of the workflow: data access. By expanding data table operations and Python-JSL interoperability, accessing data becomes simple and convenient.   Prefer video? Watch it here.   Data Table operations The jmp.from_dataframe() function provides an efficient way to convert exte...
    Evan_Carr Evan_Carr
    JMPer Cable |
    Sep 12, 2025 9:01 AM
    3625 views | 2 replies
  • Control chart warning triage in JMP Live
    Overview If you have control chart warnings, you may want to: Get notifications about warnings that nobody has investigated yet.Assign warnings to another user, or to a user group, for investigation.Stay on top of the warnings that are assigned to you for investigation.Stay focused on the processes that still need attention.Know what happened, who dealt with it, and when by reviewing and downloadi...
    Aurora_TiffanyD Aurora_TiffanyD
    JMPer Cable |
    Sep 12, 2025 8:59 AM
    2331 views | 0 replies
