%3CLINGO-SUB%20id%3D%22lingo-sub-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20blocca%20le%20larghezze%20delle%20colonne%20sulla%20larghezza%20desiderata%2C%20compresa%20la%20lunghezza%20inferiore%20al%20nome%20della%20colonna%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ED'accordo%2C%20questo%20%C3%A8%20un%20problema%20per%20me.Non%20ha%20senso%20che%20le%20larghezze%20delle%20colonne%20cambino%20quando%20non%20sto%20interagendo%20con%20quella%20colonna.Quindi%20devo%20costantemente%20modificare%20manualmente%20le%20larghezze%20delle%20colonne.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20blocca%20le%20larghezze%20delle%20colonne%20sulla%20larghezza%20desiderata%2C%20inclusa%20la%20lunghezza%20inferiore%20al%20nome%20della%20colonna%20-%20Stato%20modificato%20in%3A%20Confermato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%40danf%3C%2FA%3E%20-%3CSPAN%3E%20Grazie%20per%20il%20tuo%20suggerimento!%20Abbiamo%20catturato%20la%20tua%20richiesta%20e%20la%20prenderemo%20in%20considerazione.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Eblocca%20la%20larghezza%20delle%20colonne%20alla%20larghezza%20desiderata%2C%20inclusa%20la%20lunghezza%20inferiore%20a%20quella%20del%20nome%20della%20colonna%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EVorrei%20non%20essere%20costretto%20a%20ridimensionare%20le%20mie%20colonne%20ogni%20volta%20che%20succede%20qualcosa%20nella%20tabella%20dati.%20Vorrei%20poter%20impostare%20una%20colonna%20tramite%20JSL%20o%20manualmente%20e%20poi%20bloccarla%20in%20modo%20che%20non%20cambi%20finch%C3%A9%20non%20decido%20di%20cambiarla.%20Voglio%20anche%20poter%20bloccare%20la%20larghezza%20a%20un%20valore%20inferiore%20alla%20larghezza%20del%20nome%20della%20colonna%20in%20modo%20che%20non%20cambi%20di%20nuovo%20alla%20lunghezza%20del%20nome%20della%20colonna.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20blocca%20le%20larghezze%20delle%20colonne%20sulla%20larghezza%20desiderata%2C%20inclusa%20la%20lunghezza%20inferiore%20al%20nome%20della%20colonna%20-%20Stato%20modificato%20in%3A%20Duplicato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%20%40danf%3C%2FA%3E%20%2C%20grazie%20per%20il%20suggerimento.Abbiamo%20una%20richiesta%20esistente%20per%20questa%20funzione%20e%20questa%20%C3%A8%20in%20considerazione%20per%20una%20versione%20futura.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
lock column widths to desired width including shorter than column name length
I would like to not be forced to resize my columns every time something happens in the data table. I would like to be able to set a column either by JSL or manually and then lock it so that it doesn't change until I decide to change it. I want to be able to lock the width smaller that the column name width too so that it does not change back to the length of the column name.
3 Comments
ConradG
Level II
Agree this is an issue for me.  It doesn't make sense that the column widths would change when I'm not interacting with that column.  Then I am constantly having to manually change the column widths.
@danf -  Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Duplicate
Hello @danf , thank you for the suggestion.  We have an existing request for this feature and this is being considered for a future version.
