  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
lock column widths to desired width including shorter than column name length
I would like to not be forced to resize my columns every time something happens in the data table. I would like to be able to set a column either by JSL or manually and then lock it so that it doesn't change until I decide to change it. I want to be able to lock the width smaller that the column name width too so that it does not change back to the length of the column name.
3 Comments
ConradG
Level II
Agree this is an issue for me.  It doesn't make sense that the column widths would change when I'm not interacting with that column.  Then I am constantly having to manually change the column widths.
@danf -  Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Duplicate
Hello @danf , thank you for the suggestion.  We have an existing request for this feature and this is being considered for a future version.
