%3CLINGO-SUB%20id%3D%22lingo-sub-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ESpaltenbreiten%20auf%20die%20gew%C3%BCnschte%20Breite%20sperren%2C%20auch%20k%C3%BCrzer%20als%20die%20Spaltennamenl%C3%A4nge%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EIch%20m%C3%B6chte%20nicht%20gezwungen%20sein%2C%20die%20Gr%C3%B6%C3%9Fe%20meiner%20Spalten%20jedes%20Mal%20zu%20%C3%A4ndern%2C%20wenn%20etwas%20in%20der%20Datentabelle%20passiert.%20Ich%20m%C3%B6chte%20eine%20Spalte%20entweder%20per%20JSL%20oder%20manuell%20festlegen%20und%20sie%20dann%20sperren%20k%C3%B6nnen%2C%20sodass%20sie%20sich%20nicht%20%C3%A4ndert%2C%20bis%20ich%20mich%20dazu%20entscheide.%20Ich%20m%C3%B6chte%20auch%20die%20Breite%20kleiner%20als%20die%20Breite%20des%20Spaltennamens%20sperren%20k%C3%B6nnen%2C%20sodass%20sie%20nicht%20wieder%20auf%20die%20L%C3%A4nge%20des%20Spaltennamens%20zur%C3%BCckgesetzt%20wird.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatisierung%20und%20Skripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Spaltenbreiten%20auf%20die%20gew%C3%BCnschte%20Breite%20sperren%2C%20einschlie%C3%9Flich%20k%C3%BCrzer%20als%20die%20L%C3%A4nge%20des%20Spaltennamens%20-%20Status%20ge%C3%A4ndert%20in%3A%20Duplizieren%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHallo%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%20%40Danf%3C%2FA%3E%20%2C%20danke%20f%C3%BCr%20den%20Vorschlag.Wir%20haben%20eine%20bestehende%20Anfrage%20f%C3%BCr%20diese%20Funktion%20und%20dies%20wird%20f%C3%BCr%20eine%20zuk%C3%BCnftige%20Version%20in%20Betracht%20gezogen.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Spaltenbreiten%20auf%20die%20gew%C3%BCnschte%20Breite%20sperren%2C%20einschlie%C3%9Flich%20k%C3%BCrzer%20als%20die%20L%C3%A4nge%20des%20Spaltennamens%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Best%C3%A4tigt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%40Danf%3C%2FA%3E%20-%3CSPAN%3E%20Danke%20f%C3%BCr%20deinen%20Vorschlag!%20Wir%20haben%20Ihre%20Anfrage%20erfasst%20und%20werden%20sie%20ber%C3%BCcksichtigen.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Sperren%20Sie%20die%20Spaltenbreiten%20auf%20die%20gew%C3%BCnschte%20Breite%2C%20einschlie%C3%9Flich%20k%C3%BCrzer%20als%20die%20L%C3%A4nge%20des%20Spaltennamens%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EStimmen%20Sie%20zu%2C%20dass%20dies%20ein%20Problem%20f%C3%BCr%20mich%20ist.Es%20macht%20keinen%20Sinn%2C%20dass%20sich%20die%20Spaltenbreiten%20%C3%A4ndern%2C%20wenn%20ich%20nicht%20mit%20dieser%20Spalte%20interagiere.Dann%20muss%20ich%20st%C3%A4ndig%20die%20Spaltenbreiten%20manuell%20%C3%A4ndern.%3C%2FP%3E%3C%2FLINGO-BODY%3E
lock column widths to desired width including shorter than column name length
I would like to not be forced to resize my columns every time something happens in the data table. I would like to be able to set a column either by JSL or manually and then lock it so that it doesn't change until I decide to change it. I want to be able to lock the width smaller that the column name width too so that it does not change back to the length of the column name.
3 Comments
ConradG
Level II
Agree this is an issue for me.  It doesn't make sense that the column widths would change when I'm not interacting with that column.  Then I am constantly having to manually change the column widths.
@danf -  Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Duplicate
Hello @danf , thank you for the suggestion.  We have an existing request for this feature and this is being considered for a future version.
