%3CLINGO-SUB%20id%3D%22lingo-sub-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%20verrouiller%20les%20largeurs%20de%20colonne%20%C3%A0%20la%20largeur%20souhait%C3%A9e%2C%20y%20compris%20plus%20courte%20que%20la%20longueur%20du%20nom%20de%20la%20colonne%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ED'accord%2C%20c'est%20un%20probl%C3%A8me%20pour%20moi.Cela%20n'a%20pas%20de%20sens%20que%20les%20largeurs%20de%20colonne%20changent%20lorsque%20je%20n'interagis%20pas%20avec%20cette%20colonne.Ensuite%2C%20je%20dois%20constamment%20modifier%20manuellement%20la%20largeur%20des%20colonnes.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%26nbsp%3Bverrouiller%20les%20largeurs%20de%20colonne%20%C3%A0%20la%20largeur%20souhait%C3%A9e%2C%20y%20compris%20plus%20courte%20que%20la%20longueur%20du%20nom%20de%20la%20colonne%20-%20Statut%20chang%C3%A9%20en%26nbsp%3B%3A%26nbsp%3BReconnu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%40danf%3C%2FA%3E%20-%3CSPAN%3E%20Merci%20pour%20votre%20suggestion!%20Nous%20avons%20enregistr%C3%A9%20votre%20demande%20et%20la%20prendrons%20en%20consid%C3%A9ration.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Everrouiller%20la%20largeur%20des%20colonnes%20%C3%A0%20la%20largeur%20souhait%C3%A9e%2C%20y%20compris%20une%20longueur%20plus%20courte%20que%20le%20nom%20de%20la%20colonne%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EJe%20ne%20voudrais%20pas%20%C3%AAtre%20oblig%C3%A9%20de%20redimensionner%20mes%20colonnes%20%C3%A0%20chaque%20fois%20qu'un%20%C3%A9v%C3%A9nement%20se%20produit%20dans%20la%20table%20de%20donn%C3%A9es.%20Je%20voudrais%20pouvoir%20d%C3%A9finir%20une%20colonne%20soit%20par%20JSL%2C%20soit%20manuellement%2C%20puis%20la%20verrouiller%20afin%20qu'elle%20ne%20change%20pas%20jusqu'%C3%A0%20ce%20que%20je%20d%C3%A9cide%20de%20la%20modifier.%20Je%20veux%20%C3%A9galement%20pouvoir%20verrouiller%20la%20largeur%20plus%20petite%20que%20la%20largeur%20du%20nom%20de%20la%20colonne%20afin%20qu'elle%20ne%20revienne%20pas%20%C3%A0%20la%20longueur%20du%20nom%20de%20la%20colonne.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatisation%20et%20scripts%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%26nbsp%3Bverrouiller%20les%20largeurs%20de%20colonne%20%C3%A0%20la%20largeur%20souhait%C3%A9e%2C%20y%20compris%20plus%20courte%20que%20la%20longueur%20du%20nom%20de%20la%20colonne%20-%20Statut%20chang%C3%A9%20en%26nbsp%3B%3A%26nbsp%3BDupliquer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EBonjour%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%20%40danf%3C%2FA%3E%20%2C%20Merci%20pour%20la%20suggestion.Nous%20avons%20une%20demande%20existante%20pour%20cette%20fonctionnalit%C3%A9%20et%20celle-ci%20est%20envisag%C3%A9e%20pour%20une%20future%20version.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
lock column widths to desired width including shorter than column name length
I would like to not be forced to resize my columns every time something happens in the data table. I would like to be able to set a column either by JSL or manually and then lock it so that it doesn't change until I decide to change it. I want to be able to lock the width smaller that the column name width too so that it does not change back to the length of the column name.
3 Comments
ConradG
Level II
Agree this is an issue for me.  It doesn't make sense that the column widths would change when I'm not interacting with that column.  Then I am constantly having to manually change the column widths.
@danf -  Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Duplicate
Hello @danf , thank you for the suggestion.  We have an existing request for this feature and this is being considered for a future version.
