%3CLINGO-SUB%20id%3D%22lingo-sub-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20bloquear%20los%20anchos%20de%20columna%20al%20ancho%20deseado%2C%20incluso%20m%C3%A1s%20cortos%20que%20la%20longitud%20del%20nombre%20de%20la%20columna%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDe%20acuerdo%2C%20esto%20es%20un%20problema%20para%20m%C3%AD.No%20tiene%20sentido%20que%20los%20anchos%20de%20las%20columnas%20cambien%20cuando%20no%20estoy%20interactuando%20con%20esa%20columna.Luego%2C%20constantemente%20tengo%20que%20cambiar%20manualmente%20los%20anchos%20de%20columna.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20bloquear%20los%20anchos%20de%20columna%20al%20ancho%20deseado%2C%20incluso%20m%C3%A1s%20cortos%20que%20la%20longitud%20del%20nombre%20de%20la%20columna%20-%20El%20estado%20cambi%C3%B3%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%40danf%3C%2FA%3E%20-%3CSPAN%3E%20%C2%A1Gracias%20por%20su%20sugerencia!%20Hemos%20capturado%20su%20solicitud%20y%20la%20tomaremos%20en%20consideraci%C3%B3n.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EBloquear%20el%20ancho%20de%20las%20columnas%20al%20ancho%20deseado%2C%20incluso%20si%20es%20m%C3%A1s%20corto%20que%20la%20longitud%20del%20nombre%20de%20la%20columna%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EMe%20gustar%C3%ADa%20no%20tener%20que%20cambiar%20el%20tama%C3%B1o%20de%20mis%20columnas%20cada%20vez%20que%20sucede%20algo%20en%20la%20tabla%20de%20datos.%20Me%20gustar%C3%ADa%20poder%20configurar%20una%20columna%20mediante%20JSL%20o%20manualmente%20y%20luego%20bloquearla%20para%20que%20no%20cambie%20hasta%20que%20yo%20decida%20cambiarla.%20Tambi%C3%A9n%20quiero%20poder%20bloquear%20el%20ancho%20para%20que%20sea%20menor%20que%20el%20ancho%20del%20nombre%20de%20la%20columna%20para%20que%20no%20vuelva%20a%20cambiar%20a%20la%20longitud%20del%20nombre%20de%20la%20columna.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatizaci%C3%B3n%20y%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20bloquear%20los%20anchos%20de%20columna%20al%20ancho%20deseado%2C%20incluso%20m%C3%A1s%20cortos%20que%20la%20longitud%20del%20nombre%20de%20la%20columna%20-%20El%20estado%20cambi%C3%B3%20a%3A%20Duplicado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%20%40danf%3C%2FA%3E%20%2C%20Gracias%20por%20la%20sugerencia.Tenemos%20una%20solicitud%20existente%20para%20esta%20funci%C3%B3n%20y%20se%20est%C3%A1%20considerando%20para%20una%20versi%C3%B3n%20futura.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
lock column widths to desired width including shorter than column name length
I would like to not be forced to resize my columns every time something happens in the data table. I would like to be able to set a column either by JSL or manually and then lock it so that it doesn't change until I decide to change it. I want to be able to lock the width smaller that the column name width too so that it does not change back to the length of the column name.
3 Comments
ConradG
Level II
Agree this is an issue for me.  It doesn't make sense that the column widths would change when I'm not interacting with that column.  Then I am constantly having to manually change the column widths.
@danf -  Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Duplicate
Hello @danf , thank you for the suggestion.  We have an existing request for this feature and this is being considered for a future version.
