%3CLINGO-SUB%20id%3D%22lingo-sub-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20lock%20column%20widths%20to%20desired%20width%20including%20shorter%20than%20column%20name%20length%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537359%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EAgree%20this%20is%20an%20issue%20for%20me.%26nbsp%3B%20It%20doesn't%20make%20sense%20that%20the%20column%20widths%20would%20change%20when%20I'm%20not%20interacting%20with%20that%20column.%26nbsp%3B%20Then%20I%20am%20constantly%20having%20to%20manually%20change%20the%20column%20widths.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20lock%20column%20widths%20to%20desired%20width%20including%20shorter%20than%20column%20name%20length%20-%20Status%20changed%20to%3A%20Acknowledged%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-543119%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%40danf%3C%2FA%3E%26nbsp%3B-%26nbsp%3B%3CSPAN%3E%26nbsp%3BThank%20you%20for%20your%20suggestion!%20We%20have%20captured%20your%20request%20and%20will%20take%20it%20under%20consideration.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Elock%20column%20widths%20to%20desired%20width%20including%20shorter%20than%20column%20name%20length%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EI%20would%20like%20to%20not%20be%20forced%20to%20resize%20my%20columns%20every%20time%20something%20happens%20in%20the%20data%20table.%20I%20would%20like%20to%20be%20able%20to%20set%20a%20column%20either%20by%20JSL%20or%20manually%20and%20then%20lock%20it%20so%20that%20it%20doesn't%20change%20until%20I%20decide%20to%20change%20it.%20I%20want%20to%20be%20able%20to%20lock%20the%20width%20smaller%20that%20the%20column%20name%20width%20too%20so%20that%20it%20does%20not%20change%20back%20to%20the%20length%20of%20the%20column%20name.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-537238%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomation%20and%20Scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20lock%20column%20widths%20to%20desired%20width%20including%20shorter%20than%20column%20name%20length%20-%20Status%20changed%20to%3A%20Duplicate%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-546106%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F10469%22%20target%3D%22_blank%22%3E%40danf%3C%2FA%3E%26nbsp%3B%2C%20thank%20you%20for%20the%20suggestion.%26nbsp%3B%20We%20have%20an%20existing%20request%20for%20this%20feature%20and%20this%20is%20being%20considered%20for%20a%20future%20version.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
lock column widths to desired width including shorter than column name length
I would like to not be forced to resize my columns every time something happens in the data table. I would like to be able to set a column either by JSL or manually and then lock it so that it doesn't change until I decide to change it. I want to be able to lock the width smaller that the column name width too so that it does not change back to the length of the column name.
3 Comments
ConradG
Level II
Agree this is an issue for me.  It doesn't make sense that the column widths would change when I'm not interacting with that column.  Then I am constantly having to manually change the column widths.
@danf -  Thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
Status changed to: Duplicate
Hello @danf , thank you for the suggestion.  We have an existing request for this feature and this is being considered for a future version.
