%3CLINGO-SUB%20id%3D%22lingo-sub-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAdd%20%22rss()%22%20(root-sum-squared)%20function%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ERecommend%20adding%20%22rss()%22%20(root-sum-squared)%20function%20in%20JMP.%20%26nbsp%3BThis%20is%20very%20useful%20for%20calculating%20the%20magnitude%20of%20vectors%2C%20hypotenuse%20of%202-d%20and%203-d%20triangles%2C%20etc.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBasically%20it%20would%20take%20the%20square-root%20of%20the%20sum%20of%20the%20squared%20terms.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EMass%20Customization%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Add%20%22rss()%22%20(root-sum-squared)%20function%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%26nbsp%3B%20Agree.%20The%20%3CEM%3EDistance%3C%2FEM%3E%20function%20is%20close%2C%20flexible%2C%20but%20not%20easy%20to%20use%20or%20explain.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Ev%20%3D%20%5B3%204%5D%3B%3CBR%20%2F%3Edistance(v%2Cv*0)%5E.5%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E%5B5%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI've%20used%20this%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Esqrt(sum(%5B3%204%5D%5E2))%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ewhich%20is%20not%20immediately%20obvious%20either.%20%3CEM%3ELength%3C%2FEM%3E%20and%20%3CEM%3EAbs%3C%2FEM%3E%20are%20already%20in%20use%20with%20an%20array%20argument.%20I%20think%20%3CEM%3EMagnitude%3C%2FEM%3E%20might%20be%20a%20better%20name%20than%20%3CEM%3ERss%3C%2FEM%3E.%3C%2FP%3E%0A%3CP%3EMagnitude(%5B1%202%203%2C%204%205%206%5D)%20should%20return%20a%202%20row%20by%201%20col%20matrix.%3C%2FP%3E%0A%3CP%3EMagnitude(1%2C2%2C3)%20should%20return%20a%20scalar.%3C%2FP%3E%0A%3CP%3EOr%20%3CEM%3EHypotenuse%3C%2FEM%3E.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add "rss()" (root-sum-squared) function in JMP
Recommend adding "rss()" (root-sum-squared) function in JMP.  This is very useful for calculating the magnitude of vectors, hypotenuse of 2-d and 3-d triangles, etc.
Basically it would take the square-root of the sum of the squared terms.
1 Comment
Craige_Hales
@BHarris  Agree. The Distance function is close, flexible, but not easy to use or explain.
v = [3 4];
distance(v,v*0)^.5;
[5]
I've used this
sqrt(sum([3 4]^2))
5
which is not immediately obvious either. Length and Abs are already in use with an array argument. I think Magnitude might be a better name than Rss.
Magnitude([1 2 3, 4 5 6]) should return a 2 row by 1 col matrix.
Magnitude(1,2,3) should return a scalar.
Or Hypotenuse.
