Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Recommend adding "rss()" (root-sum-squared) function in JMP. This is very useful for calculating the magnitude of vectors, hypotenuse of 2-d and 3-d triangles, etc.
Basically it would take the square-root of the sum of the squared terms.
