%3CLINGO-SUB%20id%3D%22lingo-sub-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAgregue%20la%20funci%C3%B3n%20%22rss()%22%20(suma%20cuadrada)%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ESe%20recomienda%20agregar%20la%20funci%C3%B3n%20%22rss()%22%20(suma%20de%20ra%C3%ADces%20cuadradas)%20en%20JMP.%20Esto%20es%20muy%20%C3%BAtil%20para%20calcular%20la%20magnitud%20de%20vectores%2C%20hipotenusa%20de%20tri%C3%A1ngulos%20bidimensionales%20y%20tridimensionales%2C%20etc.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EB%C3%A1sicamente%20tomar%C3%ADa%20la%20ra%C3%ADz%20cuadrada%20de%20la%20suma%20de%20los%20t%C3%A9rminos%20al%20cuadrado.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ELa%20personalizaci%C3%B3n%20en%20masa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20A%C3%B1adir%20la%20funci%C3%B3n%20%22rss()%22%20(ra%C3%ADz-suma-cuadrada)%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20Aceptar.%20los%3CEM%3E%20Distancia%3C%2FEM%3E%20La%20funci%C3%B3n%20es%20cercana%2C%20flexible%2C%20pero%20no%20f%C3%A1cil%20de%20usar%20o%20explicar.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Ev%20%3D%20%5B3%204%5D%3B%3CBR%20%2F%3Edistance(v%2Cv*0)%5E.5%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E%5B5%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ehe%20usado%20esto%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Esqrt(sum(%5B3%204%5D%5E2))%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eque%20tampoco%20es%20inmediatamente%20obvio.%20%3CEM%3ELongitud%3C%2FEM%3E%20y%3CEM%3E%20Abdominales%3C%2FEM%3E%20ya%20est%C3%A1n%20en%20uso%20con%20un%20argumento%20de%20matriz.%20pienso%3CEM%3E%20Magnitud%3C%2FEM%3E%20podr%C3%ADa%20ser%20un%20mejor%20nombre%20que%3CEM%3E%20RSS%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3EMagnitud%20(%5B1%202%203%2C%204%205%206%5D)%20debe%20devolver%20una%20matriz%20de%202%20filas%20por%201%20columna.%3C%2FP%3E%0A%3CP%3EMagnitude(1%2C2%2C3)%20deber%C3%ADa%20devolver%20un%20escalar.%3C%2FP%3E%0A%3CP%3EO%3CEM%3E%20Hipotenusa%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add "rss()" (root-sum-squared) function in JMP
Recommend adding "rss()" (root-sum-squared) function in JMP.  This is very useful for calculating the magnitude of vectors, hypotenuse of 2-d and 3-d triangles, etc.
Basically it would take the square-root of the sum of the squared terms.
1 Comment
Craige_Hales
@BHarris  Agree. The Distance function is close, flexible, but not easy to use or explain.
v = [3 4];
distance(v,v*0)^.5;
[5]
I've used this
sqrt(sum([3 4]^2))
5
which is not immediately obvious either. Length and Abs are already in use with an array argument. I think Magnitude might be a better name than Rss.
Magnitude([1 2 3, 4 5 6]) should return a 2 row by 1 col matrix.
Magnitude(1,2,3) should return a scalar.
Or Hypotenuse.
