%3CLINGO-SUB%20id%3D%22lingo-sub-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EF%C3%BCgen%20Sie%20die%20Funktion%20%E2%80%9Erss()%E2%80%9C%20(root-sum-squared)%20in%20JMP%20hinzu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EEs%20wird%20empfohlen%2C%20die%20Funktion%20%E2%80%9Erss()%E2%80%9C%20(root-sum-squared)%20in%20JMP%20hinzuzuf%C3%BCgen.%20Dies%20ist%20sehr%20n%C3%BCtzlich%20zum%20Berechnen%20der%20Gr%C3%B6%C3%9Fe%20von%20Vektoren%2C%20der%20Hypothenuse%20von%202-D-%20und%203-D-Dreiecken%20usw.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EIm%20Grunde%20genommen%20w%C3%BCrde%20man%20die%20Quadratwurzel%20aus%20der%20Summe%20der%20quadrierten%20Terme%20ziehen.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EMassenanpassung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Funktion%20%E2%80%9Erss()%E2%80%9C%20(Wurzelsummenquadrat)%20in%20JMP%20hinzuf%C3%BCgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20Zustimmen.%20Der%3CEM%3E%20Distanz%3C%2FEM%3E%20Die%20Funktion%20ist%20nah%20und%20flexibel%2C%20aber%20nicht%20einfach%20zu%20verwenden%20oder%20zu%20erkl%C3%A4ren.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Ev%20%3D%20%5B3%204%5D%3B%3CBR%20%2F%3Edistance(v%2Cv*0)%5E.5%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E%5B5%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIch%20habe%20das%20verwendet%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Esqrt(sum(%5B3%204%5D%5E2))%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ewas%20auch%20nicht%20sofort%20ersichtlich%20ist.%20%3CEM%3EL%C3%A4nge%3C%2FEM%3E%20Und%3CEM%3E%20Abs%3C%2FEM%3E%20werden%20bereits%20mit%20einem%20Array-Argument%20verwendet.%20Ich%20finde%3CEM%3E%20Gr%C3%B6%C3%9Fe%3C%2FEM%3E%20k%C3%B6nnte%20ein%20besserer%20Name%20sein%20als%3CEM%3E%20Rss%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3EMagnitude(%5B1%202%203%2C%204%205%206%5D)%20sollte%20eine%20Matrix%20mit%202%20Zeilen%20mal%201%20Spalte%20zur%C3%BCckgeben.%3C%2FP%3E%0A%3CP%3EMagnitude(1%2C2%2C3)%20sollte%20einen%20Skalar%20zur%C3%BCckgeben.%3C%2FP%3E%0A%3CP%3EOder%3CEM%3E%20Hypotenuse%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add "rss()" (root-sum-squared) function in JMP
Recommend adding "rss()" (root-sum-squared) function in JMP.  This is very useful for calculating the magnitude of vectors, hypotenuse of 2-d and 3-d triangles, etc.
Basically it would take the square-root of the sum of the squared terms.
1 Comment
Craige_Hales
@BHarris  Agree. The Distance function is close, flexible, but not easy to use or explain.
v = [3 4];
distance(v,v*0)^.5;
[5]
I've used this
sqrt(sum([3 4]^2))
5
which is not immediately obvious either. Length and Abs are already in use with an array argument. I think Magnitude might be a better name than Rss.
Magnitude([1 2 3, 4 5 6]) should return a 2 row by 1 col matrix.
Magnitude(1,2,3) should return a scalar.
Or Hypotenuse.
