%3CLINGO-SUB%20id%3D%22lingo-sub-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAjouter%20la%20fonction%20%22rss()%22%20(somme%20racine%20au%20carr%C3%A9)%20dans%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EIl%20est%20recommand%C3%A9%20d'ajouter%20la%20fonction%20%22rss()%22%20(somme%20racine%20au%20carr%C3%A9)%20dans%20JMP.%20Ceci%20est%20tr%C3%A8s%20utile%20pour%20calculer%20la%20magnitude%20des%20vecteurs%2C%20l'hypot%C3%A9nuse%20des%20triangles%202D%20et%203D%2C%20etc.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EFondamentalement%2C%20cela%20prendrait%20la%20racine%20carr%C3%A9e%20de%20la%20somme%20des%20termes%20au%20carr%C3%A9.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EPersonnalisation%20de%20masse%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Ajouter%20la%20fonction%20%22rss()%22%20(somme%20racine%20au%20carr%C3%A9)%20dans%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20Accepter.%20Le%3CEM%3E%20Distance%3C%2FEM%3E%20la%20fonction%20est%20proche%2C%20flexible%2C%20mais%20pas%20facile%20%C3%A0%20utiliser%20ou%20%C3%A0%20expliquer.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Ev%20%3D%20%5B3%204%5D%3B%3CBR%20%2F%3Edistance(v%2Cv*0)%5E.5%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E%5B5%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EJ'ai%20utilis%C3%A9%20%C3%A7a%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Esqrt(sum(%5B3%204%5D%5E2))%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ece%20qui%20n%E2%80%99est%20pas%20non%20plus%20imm%C3%A9diatement%20%C3%A9vident.%20%3CEM%3ELongueur%3C%2FEM%3E%20et%3CEM%3E%20Abdos%3C%2FEM%3E%20sont%20d%C3%A9j%C3%A0%20utilis%C3%A9s%20avec%20un%20argument%20tableau.%20Je%20pense%3CEM%3E%20Ordre%20de%20grandeur%3C%2FEM%3E%20pourrait%20%C3%AAtre%20un%20meilleur%20nom%20que%3CEM%3E%20RSS%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3EMagnitude(%5B1%202%203%2C%204%205%206%5D)%20devrait%20renvoyer%20une%20matrice%20de%202%20lignes%20par%201%20col.%3C%2FP%3E%0A%3CP%3EMagnitude(1%2C2%2C3)%20devrait%20renvoyer%20un%20scalaire.%3C%2FP%3E%0A%3CP%3EOu%3CEM%3E%20Hypot%C3%A9nuse%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add "rss()" (root-sum-squared) function in JMP
Recommend adding "rss()" (root-sum-squared) function in JMP.  This is very useful for calculating the magnitude of vectors, hypotenuse of 2-d and 3-d triangles, etc.
Basically it would take the square-root of the sum of the squared terms.
1 Comment
Craige_Hales
@BHarris  Agree. The Distance function is close, flexible, but not easy to use or explain.
v = [3 4];
distance(v,v*0)^.5;
[5]
I've used this
sqrt(sum([3 4]^2))
5
which is not immediately obvious either. Length and Abs are already in use with an array argument. I think Magnitude might be a better name than Rss.
Magnitude([1 2 3, 4 5 6]) should return a 2 row by 1 col matrix.
Magnitude(1,2,3) should return a scalar.
Or Hypotenuse.
