%3CLINGO-SUB%20id%3D%22lingo-sub-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAggiungi%20la%20funzione%20%22rss()%22%20(radice%20somma%20quadrata)%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EConsigliamo%20di%20aggiungere%20la%20funzione%20%22rss()%22%20(root-sum-squared)%20in%20JMP.%20Questo%20%C3%A8%20molto%20utile%20per%20calcolare%20il%20modulo%20dei%20vettori%2C%20l'ipotenusa%20dei%20triangoli%202-d%20e%203-d%2C%20ecc.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EFondamentalmente%20ci%20vorrebbe%20la%20radice%20quadrata%20della%20somma%20dei%20termini%20quadrati.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-284781%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Aggiungere%20la%20funzione%20%22rss()%22%20(radice-somma-quadrata)%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-555847%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12313%22%20target%3D%22_blank%22%3E%40BHarris%3C%2FA%3E%20Essere%20d'accordo.%20IL%3CEM%3E%20Distanza%3C%2FEM%3E%20la%20funzione%20%C3%A8%20vicina%2C%20flessibile%2C%20ma%20non%20facile%20da%20usare%20o%20spiegare.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Ev%20%3D%20%5B3%204%5D%3B%3CBR%20%2F%3Edistance(v%2Cv*0)%5E.5%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E%5B5%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHo%20usato%20questo%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Esqrt(sum(%5B3%204%5D%5E2))%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3E5%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eanche%20questo%20non%20%C3%A8%20immediatamente%20evidente.%20%3CEM%3ELunghezza%3C%2FEM%3E%20E%3CEM%3E%20Addominali%3C%2FEM%3E%20sono%20gi%C3%A0%20in%20uso%20con%20un%20argomento%20array.%20Penso%3CEM%3E%20Grandezza%3C%2FEM%3E%20potrebbe%20essere%20un%20nome%20migliore%20di%3CEM%3E%20Rss%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3EMagnitude(%5B1%202%203%2C%204%205%206%5D)%20dovrebbe%20restituire%20una%20matrice%20di%202%20righe%20per%201%20col.%3C%2FP%3E%0A%3CP%3ELa%20grandezza(1%2C2%2C3)%20dovrebbe%20restituire%20uno%20scalare.%3C%2FP%3E%0A%3CP%3EO%3CEM%3E%20Ipotenusa%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add "rss()" (root-sum-squared) function in JMP
Recommend adding "rss()" (root-sum-squared) function in JMP.  This is very useful for calculating the magnitude of vectors, hypotenuse of 2-d and 3-d triangles, etc.
Basically it would take the square-root of the sum of the squared terms.
1 Comment
Craige_Hales
@BHarris  Agree. The Distance function is close, flexible, but not easy to use or explain.
v = [3 4];
distance(v,v*0)^.5;
[5]
I've used this
sqrt(sum([3 4]^2))
5
which is not immediately obvious either. Length and Abs are already in use with an array argument. I think Magnitude might be a better name than Rss.
Magnitude([1 2 3, 4 5 6]) should return a 2 row by 1 col matrix.
Magnitude(1,2,3) should return a scalar.
Or Hypotenuse.
