BookmarkSubscribeRSS Feed
juliagong
Staff (Retired)
13 helpful (and lucky) JMP scripting tips
Syntax got your tongue? I've compiled 13 JMP Scripting Language tips that I've found handy while learning JSL syntax:
1. Concatenating strings (see Craige Hales' post on this)
places = {"world", "planet", "globe", "Earth"};
statement = "Hello " || places[2] || "!";
The above code creates the string "Hello planet!"
2. Referring to table column names that have special characters
Let's say your table, dt, has a column named "Prob(Pred)" (probability of prediction). If you reference it as
dt:Prob(Pred)
it won't work. You need to use quotes:
dt:"Prob(Pred)"
3. Referencing a particular file in addin (see PMroz's original solution)
To work with a file contained within your jmpaddin, you should refer to your file as:
"$ADDIN_HOME(com.mycompany.test_addin)\myfile.jmp"
4. Changing Text Box font color, size and type
myText = Text Box(statement, <<Font Color("Blue"), <<JustifyText("center"), <<Set Wrap(80), <<Set Font("Segoe UI", 15));
DemoText
(To center the text in the window, you'll need to add Spacer Boxes on either side of the text in a H List Box -- see tip #12.)
5. Saving a graph/plot in a report as an image (sample data (iris) also seen on discriminant analysis report page)
First, use the point-and-click interface and generate the model you want. After this, click the little red triangle, go to Script > Save Script to Script Window. Don't close your model window yet.
In the new script window, assign the model a name; for example, I can name my discriminant plot discrimGraph:
discrimGraph = Discriminant([...generated code...]);
Make this generated model a report:
report = discrimGraph << report;
Go back to your model window, right-click on the graph or figure you want to save, and go to Edit > Show Tree Structure. This will tell you the name of the object you want to grab (often, the HelpKey will guide you to the right box). Here, I want to grab a Frame Box:
reportBox = report[Frame Box(1)];
Finally, if you want to convert reportBox into an image that you can save:
modelImage = reportBox << getPicture();
You now have a variable name attached to the specific graph or plot that you've generated. If you want to save this as an image to your computer:
modelImage << Save Image("C:\Documents\JMP\myImage.png", png);
Often, PNG images look better, but are larger files.
DiscrimBefore
6. Deselecting all rows in a data table
This one is pretty straightforward; select all rows, and invert the selection. This won't affect row markers.
dt << select all rows;
dt << invert row selection;
7. Building a user interface in JMP -- resizing windows
If you want to resize a window to particular dimensions in pixels (note: this includes the outer frame of the window, not just its contents):
win << Set Window Size(width, height);
8. Setting the background color for a graph or plot
I often needed my white-background plots to blend in with the default gray of the display box:
myGraph[framebox(1)] << Set Background Color({0.97255, 0.97255, 0.97255});
The order for the three arguments is R, G, B; remember to convert your desired RGB values from a 0 - 255 scale to a 0 - 1 scale (divide desired value by 255).
DiscrimBefore  DiscrimAfter
9. Discriminant analysis -- removing biplot rays for clarity
In the point-and-click interface of your model, go to the little red triangle > Canonical Options > Show Biplot Rays. If you want the script for removing the biplot rays, now go to Script > Save Script to Script Window, and you'll see the argument that makes this change is
Show Biplot Rays( 0 ),
DiscrimWithoutBiplotRays
10. Building a user interface in JMP -- changing Spacer Box size
Where the first argument is horizontal size, and the second argument is vertical size (both in pixels):
SpacerBox(Size(h, v))
11. Building a user interface in JMP -- auto-resizing spacers
Spacers can auto-adapt in one direction (when window contents change) if you leave out one of the arguments:
SpacerBox(Size(, 1))
12. Building a user interface in JMP -- justifying all boxes in a display tree window
Line Up Box() is your friend. You can use it to align all the given boxes within it:
Line Up Box(
H List Box(Align("center"),
SpacerBox(),
Text Box("Hello, planet!"),
SpacerBox()
SpacerBox(),
Button Box("Click me", afterClick()),
SpacerBox()
DemoText1
13. Scaling/resizing, cropping images
This scales down the image by 50 percent in both dimensions:
myImage << scale(0.5);
This crops the image to the dimensions you want (in pixels):
myImage << crop(left(startingColumn), right(endingColumn), top(startingRow), bottom(endingRow));
I hope these 13 tips will be as lucky for you as they have been for me!
Here are some additional resources that I found very helpful:
  • Manipulating DisplaysDisplays, Display Boxes, and Display Trees
  • JMP Scripting Guide
  • Rows and Row States
  • Character Functions
  • One-page JMP Guides
  • Online JMP Scripting Guide Index
  • One more thing: I'll be presenting a poster at Discovery Summit, so if you have a chance, please stop by!
    5 Comments
     Can you expand on point 11 ?
    @David_Burnham, a Spacer Box with no arguments is configured as a stretchable spacer, with initial size=1, min=0, max=30000.  This box will grow and shrink with the window size:
    SpacerBox()
    When a non-zero size is specified, the spacer has fixed size, with size=min=max:
    SpacerBox(Size(h,v))
    Tip 11 is pointing out that you can mix the behaviors by omitting one of h or v.  You can also get the same behavior by passing -1 for the missing argument.
    Community Trekker
    Are there functions or messages for increasing the button box font/size?  Thank you in advance.
    @RBILLC, you can use mouse box to create your own button, where you can control the font size. See Example below.
    Custom Button = Function({text,callbackExpr=Expr(),textSize=0},
    	margin = Max( 5, textSize / 2 ); // guestimate a good left/right margin based on the font size
    	Eval(
    		Eval Expr( // to eval the callback expression
    			Border Box( left( 2 ), right( 2 ), top( 2 ), bottom( 2 ), // spacing around the button
    				Mouse Box(
    					Border Box( left( margin ), right( margin ), top(2),bottom(2), Sides( 15 ),
    						Text Box( text, <<Set Font Size( textSize ) ),
    						<<Set Color( {172,172,172} ),
    						<<Background Color( {238,238,238} )
    					<<Set Track Enable( 1 ),
    					<<Set Track( // function is fired while hovering over the button
    						Function({this,clickpt},
    							if( clickpt[1] < 0, // if the mouse has moved away from the button
    								// reset colors to default
    								(this << child) <<Set Color( {172,172,172} ) <<Background Color( {238,238,238} );
    								// if still hovering, set the colors to have a bluish tint
    								// these colors are taken from the Windows 10 buttons
    								(this << child) <<Set Color( {126,180,234} ) <<Background Color( {225,238,252} );
    					<<Set Click Enable( 1 ),
    					<<Set Click( // When the button is clicked
    						Function({this,clickpt,event},
    							// If the event is the pressed event, run the callback expression
    							If( event == "Pressed",
    								Expr( Name Expr( callbackExpr ) )
    New Window( "Example",
    	Custom Button( "Default - Click Me!", Expr( Throw( "You clicked me!" ) ) ),
    	Custom Button( "20 - Click Me!", Expr( Throw( "You clicked me!" ) ), 20 ),
    	Custom Button( "30 - Click Me!", Expr( Throw( "You clicked me!" ) ), 30 )
    Here's a GIF of it in action:
    Community Trekker
    Thank you that is great, how about also increasing the font size of a ComboxBox? I cannot find any funtions or messages for this in the scripting index or on the forums.
