Jackie_
Sserializing column groups
Hi @txnelson ,
 want to assign numbers only to a particular group of columns.
For eg: In this case, I want to serialize the column group "Tests". There are more than 100 columns in the tests groups. Please can you help me with the jsl?
Many thanks,
Jack
Re: Sserializing column groups
One just needs to get the list of columns in the data table group and then change the names.
theGroup = dt << get column group( "Tests" );
For( i = 1, i <= N Items( theGroup ), i++,
	theGroup[i] << set name( Char( i ) || ". " || char( theGroup[i] << get name ) )
