robot
Set Cell Size with JSL
I am trying to create an expression column in JMP12 that will hold images grabbed from a URL.  It is possible to define the cell size (width and height) using JSL?
I have not gotten the width() property to work for an Expression column, but I find I can set the column width by first creating the column as a Character, and then changing the data type to Expression:
dt << New Column( "Image", Character, "Nominal", Width( 20 ), Formula( New Image( Open( "URL" ) ) ) );
Column( "Image" ) << Data Type( Expression );
How can I define the row height with JSL?
chungwei
Staff (Retired)
Re: Set Cell Size with JSL
Cell height applies to all rows of the data table, and Display Width applies to a specific column.
dt = current data table();
w = :Height << Get Display Width;
:Height << Set Display Width( 2 * w );
ht = dt << Get Cell Height;
dt << set cell height(2*ht);
The above JSL will change the display width of height to twice its original width,
and the rows height to twice its original height.
chungwei
Staff (Retired)
robot
Thanks ChungWei.  I missed that function.
Hi Chungwei,
I used the solution to change the data table and that works. But when I make the data table into a journal the width and heights are not taken into account. Then the default height and width are used.
I use :
dt << Journal();
Do you have an idea how to do this?
Best regards,
Jeroen
