Because the data is manually entered this will most likely not handle all special cases, but seems to be working for current values:
//Test table
dt = New Table("Untitled 4993",
Compress File When Saved(1),
New Column("ProductName",
Character,
"Nominal",
Set Values(
{"AABBCC_07-08_13", "AABBCC_07-08_13", "AABBCC_07-08_13", "AABBCC_09-12", "AABBCC_09-12", "AABBCC_09-12", "AABBCC_09-12", "EEFFGG_02",
"HHIIJJ_01-07", "HHIIJJ_01-07", "HHIIJJ_01-07", "HHIIJJ_01-07", "HHIIJJ_01-07", "HHIIJJ_01-07", "HHIIJJ_01-07", "KKLLLMM_01-03_05-08",
"KKLLLMM_01-03_05-08", "KKLLLMM_01-03_05-08", "KKLLLMM_01-03_05-08", "KKLLLMM_01-03_05-08", "KKLLLMM_01-03_05-08", "KKLLLMM_01-03_05-08",
"NNOOPP_01_04_05-08", "NNOOPP_01_04_05-08", "NNOOPP_01_04_05-08", "NNOOPP_01_04_05-08", "NNOOPP_01_04_05-08", "NNOOPP_01_04_05-08",
"QQRRSS_09_11_13_14", "QQRRSS_09_11_13_14", "QQRRSS_09_11_13_14", "QQRRSS_09_11_13_14", "N4TA47_13-14-15-16-17-18", "N4TA59_13-19", "N4PX74-01-06"}
Summarize(dt, uniqProd = by(:ProductName));
newVals = Associative Array();
For Each({prodname_str}, uniqProd,
prodPart = Word(1, prodname_str, "_-");
serialPart = Substr(prodname_str, Length(prodPart) + 2);
//find and remove next range from serialPart
newVals[prodname_str] = {};
While(Length(serialPart) > 0 & serialPart != "_" & serialPart != "-",
nextRange = Regex(serialPart, "\d*-\d*");
If(IsMissing(nextRange),
break();
serialPart = Substitute(serialPart, nextRange, "");
If(Contains({"-", "_" }, Substr(serialPart, 1, 1)),
serialPart = Substr(serialPart, 2); //remove -_ if first character
nextRange = Words(nextRange, "-");
rangeVals = Index(Num(nextRange[1]), Num(nextRange[2]));
For Each({val}, rangeVals,
val = char(val);
val = Substr("00", Length(val) + 1) || val;
Insert Into(newVals[prodname_str], prodPart||"-"||val);
singleVals = Transform Each({val}, Words(serialPart, "_"),
val = char(val);
prodPart||"-"||val;
Insert Into(newVals[prodname_str], singleVals);
vals = {{}, {}};
For Each({{key, value}}, newVals,
productname_list = Repeat({key}, N Items(value));
Insert Into(vals[1], productname_list);
Insert Into(vals[2], Sort List(value));
//add values to new table
dt = New Table("Productname",
New Column("ProductName", Character, "Nominal", Set Values({})),
New Column("OUTPUT", Character, "Nominal", Set Values({}))
dt:ProductName << Set Values(vals[1]);
dt:OUTPUT << Set Values(vals[2]);
