BookmarkSubscribe
Hegedus
Community Trekker
Log showing error, but manual execution does not flag error
I have a simple script to do six bivariates and arrange them in rows.  The graphs appear to be correct, but the log is showing an error.  When I do the manual fit via the dialog box the plots get generated (without the arrange in rows), but without any error being flagged.  I am writing this script to distribute so I would like to resolve this error.  Where should I start looking?
Thanks in advance
Andy
Name Unresolved: By in access or evaluation of 'By' , By( :device_ID ) /*###*/Exception in platform launch in access or evaluation of 'Fit Group' , Fit Group(/*###*/Bivariate( Y( :Charge_Transfer_%0 ), X( :cycle_num ) ),
Bivariate( Y( :TvB_%0 ), X( :cycle_num ) ),
Bivariate( Y( :TvD_%0 ), X( :cycle_num ) ),
Bivariate( Y( :Name( "a*_%0" ) ), X( :cycle_num ) ),
Bivariate( Y( :Name( "b*_%0" ) ), X( :cycle_num ) ),
Bivariate( Y( :Name( "L*_%0" ) ), X( :cycle_num ) ),
<<{Arrange in Rows( 6 )},
By( :device_ID )
In the following script, error marked by /*###*/
Fit Group(
dt<<currentdatatable();
dt<<clear row states;
New Window( "Fitness - Bivariate",
	V List Box(
		Fit Group(
			Bivariate( Y( :name("Charge_Transfer_%0" )), X( :cycle_num ) ),
			Bivariate( Y( :name("TvB_%0" )), X( :cycle_num ) ),
			Bivariate( Y( :name("TvD_%0" )), X( :cycle_num ) ),
			By( :name("device_ID") )
Staff (Retired)
Re: Log showing error, but manual execution does not flag error
Appears to be a bug in JMP 12, fixed in 13. It looks like JMP's FitGroup attempts to evaluate the by statement, in addition to actually using it to make by groups. You can work around the problem like this:
dt=open("C:\Program Files\SAS\JMPPRO\12\Samples\Data/big class.jmp");
by=0; // work around JMP 12 issue
New Window( "Big Class - Bivariate",
  V List Box(
    dt<<Fit Group(
      Bivariate( Y( :height ), X( :age ) ),
      Bivariate( Y( :weight ), X( :age ) ),
      <<{Arrange in Rows( 2 )},
      By( :name( "sex" ) )
Now JMP can evaluate the variable "by" (and ignore the zero result) without producing messages in the log.
Edit: make it clear this problem is in FitGroup.
12 REPLIES 12
Hegedus
Community Trekker
Any help folks?
If I run the script the graphs get made but it is still throwing errors?
mikedriscoll
Community Trekker
I ran a  modified version of your script, modified to match my data, and I couldn't get it to throw that error even if I deleted the column. It seems to be flagging as if it can't find the column. The fact that it is working almost seems like a JMP version issue, some cosmetic bug that was cleaned up in a later verison. What JMP version are you using?
Staff (Retired)
Try this
dt=open("$sample_data/big class.jmp");
  V List Box(
    dt<<Fit Group(
which is probably only different in sending the fit group message to an explicit dt.
Hegedus
Community Trekker
I am having real trouble with this.
I need to embed this in a longer script.  I think it is now have a related but larger issue.  The script makes serveral data tables and it is now trying to execute this the wrong data table even if a speficially set the the data table. Notice that the Fitness- Bivariate fit is being attached to the ....SPU.Data table even though  I speciffically set the other data table.  If I bring the desired data table to the for and highlight the script for the new window and execute.  It will give the correct plots but STILL throw the errors.  If executed in the script it doesn't even do that but rather gives me a "Not Found in access or evaluation of BiVariate, Bad Arguement.
I am using JMP 12.2.0 on both Mac and Windows.
HELP!
datatable(OpticalData);
	V List Box(
		Fit Group(
			By( :name("device_id") )
OpticalData<<select where(:outlier !="---");
OpticalData<<exclude;
OpticalData<< markers("x");
OpticalData<<clear select;
This might provide you with the solution.  Force the Bivariates to operate on the correct table
	V List Box(
		Fit Group(
			OpticalData << Bivariate( Y( :name( "Charge_Transfer_%0" ) ), X( :cycle_num ) ),
			OpticalData << Bivariate( Y( :name( "TvB_%0" ) ), X( :cycle_num ) ),
			OpticalData << Bivariate( Y( :name( "TvD_%0" ) ), X( :cycle_num ) ),
			OpticalData << Bivariate( Y( :Name( "a*_%0" ) ), X( :cycle_num ) ),
			OpticalData << Bivariate( Y( :Name( "b*_%0" ) ), X( :cycle_num ) ),
			OpticalData << Bivariate( Y( :Name( "L*_%0" ) ), X( :cycle_num ) ),
			By( :name( "device_id" ) )
OpticalData << select where( :outlier != "---" );
OpticalData << exclude;
OpticalData << markers( "x" );
OpticalData << clear select;
mikedriscoll
Community Trekker
Along the lines of what I think JIm is trying to say, datatable() doesn't make that table the current one, at least I don't think it does. I think you want current data table(table name)
Hegedus
Community Trekker
Hi
Made 2 changes:
1 current data table (opticaldata)
2. forced Bivariate to optical data
As suggested.
Currently it makes the plots so that is progress.  But it is not respecting the by device_id.  It makes plots with the fir groups and has the correct ids attached, but the plots show all the data not the subset that should be defined by device_id.  Additionally the log is showing errors with name unresolved device_id.
If I create a table script and execute that way it plots correctly, but the log is still complaining about device_id.
Andy
 as suggested.
mikedriscoll
Community Trekker
Are you absolutely certain you've got the name of the 'by' column exactly correct? It worked fine for me with my modified dataset, with both the by(name("colname")) syntax or just by(:colname).
You can try putting something like this just before the bivariate code and seeing what it displays in the log.
show(as column(:device_id)[1])
It should display the value of the first row for that column. If not, figure out why and that will probably be your answer.
You could also try show(as column(OpticalData, :device_id)[1])
Sorry, I would have suggested this before... I thought your plots were correct.
cwillden
It would probably be a lot easier to resolve this if you post a sanitized version of your data set we can test use for troubleshooting.  If you're worried about IP, just replace the values in your response column with random numbers or something.
-- Cameron Willden
