You might be interested in https://community.jmp.com/t5/JMP-Blog/How-to-create-an-axis-break-in-JMP/ba-p/30611, which shows another way to add an axis break: by adding a duplicate of the variable and adjusting each part to only show a fraction. Here's what it looks like on jthi's data, but changing the x variable (column 2) back to continuous:
I did some clean-up, changing the colors to all be the same, but would also want to edit the Legend Settings to hide the extra legend entries.
Graph Builder(
	Size( 973, 455 ),
	Graph Spacing( 15 ),
	Variables( X( :Column 2 ), X( :Column 2 ), X( :Column 2 ), Y( :Column 1 ) ),
	Elements( Position( 1, 1 ), Bar( X, Y, Legend( 7 ) ) ),
	Elements( Position( 2, 1 ), Bar( X, Y, Legend( 8 ) ) ),
	Elements( Position( 3, 1 ), Bar( X, Y, Legend( 9 ) ) ),
		Dispatch( {}, "Column 2", ScaleBox,
			{Min( 20oct2022 + 00:01:00 ), Max(20oct2022 + 03:59:00 ), Interval( "Hour" ),
			Inc( 1 ), Minor Ticks( 0 )}
		Dispatch( {}, "Column 2", ScaleBox( 2 ),
			{Min( 21oct2022 + 00:01:00 ), Max(21oct2022 + 03:59:00 ), Interval( "Hour" ),
		Dispatch( {}, "Column 2", ScaleBox( 3 ),
			{Min( 22oct2022 + 00:01:00 ), Max(22oct2022 + 03:59:00 ), Interval( "Hour" ),
		Dispatch( {}, "400", ScaleBox,
			{Legend Model( 7,
				Properties( 0, {Fill Color( 5 )}, Item ID( "Column 1", 1 ) )
			), Legend Model( 8,
			), Legend Model( 9,
