mysteriouskrypt
How to Use a Variable for Custom Value Order in JMP Scripting?
Hi everyone,
I'm trying to set a custom value order in a column using JSL. Here's the code that works when I hardcode the list:
TestTable:Origin << Set Property(
"Value Order",
{Custom Order({"EU", "IND", "US", "JPN", "AU"}), Common Order(0)}
However, when I try to pass the list as a variable, it doesn't work:
countriesOrder = {"EU", "IND", "US", "JPN", "AU"};
"Value Order",
{Custom Order(countriesOrder), Common Order(0)}
My goal is to read the country order from an Excel file and use that list dynamically. But I can't find documentation on what Custom Order() accepts—whether it can take a variable or only a literal list.
Re: How to Use a Variable for Custom Value Order in JMP Scripting?
A variable within a JMP list will not be evaluated unless forced.  Try this
Eval(
	Eval Expr(
			"Value Order",
			{Custom Order( Expr( countriesOrder ) ), Common Order( 0 )}
Eval(
	Eval Expr(
			"Value Order",
