hogi
Level XIII
GraphBuilder Challenge
A Jmp graph with different Overlay categories - with a trick it's possible to create it:
on the left: weight split by # doors
on the right: weight split by year.
Besides the trick, how can I use Overlay to create the graph?
dt = Open( "$SAMPLE_DATA/Cars.jmp" );
dt << New Column( "Count_Make",	Formula( Col Number( 1, :Make ) ));
dt << Graph Builder(
	Variables( X( :Make ), X( :Make ), Y( :Wt ), Overlay( :Year, :Doors ) ),
	Elements( Position( 1, 1 ), Box Plot( X, Y,Overlay( 2 ) ) ),
	Elements( Position( 2, 1 ), Box Plot( X, Y,Overlay( 1 ) ) ),
	Local Data Filter(
		Add Filter( columns( :Count_Make ), Where( :Count_Make >= 25 ) )
Re: GraphBuilder Challenge
Is it necessary to use Overlay (if you need coloring, color supports multiple columns but I would most likely just rely on X-axis having both categories visible)
Graph Builder(
	Size(1024, 632),
	Show Control Panel(0),
	Include Missing Categories(1),
	Variables(X(:Make), X(:Doors, Position(1)), X(:Make), X(:Year, Position(2)), Y(:Wt), Color(:Doors), Color(:Year)),
	Elements(Position(1, 1), Box Plot(X(1), X(2), Y, Color(1), Legend(8))),
	Elements(Position(2, 1), Box Plot(X(1), X(2), Y, Color(2), Legend(3))),
	Local Data Filter(Add Filter(columns(:Count_Make), Where(:Count_Make >= 25.81))),
		Dispatch({}, "Make", ScaleBox, {Label Row(1, Show Major Labels(0)), Label Row(2, Show Major Grid(1))}),
		Dispatch({}, "Make", ScaleBox(2), {Label Row(1, Show Major Labels(0)), Label Row(2, Show Major Grid(1))})
or without color
hogi
Level XIII
nice trick :)
and this one?
on the left: cases split by region
on the right: cases split by year
once Overlay by multiple columns is available, it will be:
dt = Open( "$SAMPLE_DATA/Seasonal Flu.jmp" );
	Transform Column( "Year", Formula( Year( :Date ) ) ),
	Transform Column( "Day of Year", Formula( Day Of Year( :Date ) ) ),
	Variables(
		X( :Day of Year ),
		X( :Day of Year ),
		Y( :Flu Cases ),
		Overlay( :Year, :Region )
	Elements(
		Position( 1, 1 ),
		Smoother( X, Y, Overlay( 2 ))
	Elements( Position( 2, 1 ), Smoother( X, Y, Overlay( 1 )))
hogi
Level XIII
any idea?
