SpannerHead
Select column group from a list
Using an associative array, I have a list containing the titles of column groups (common).  I tried to use select column group with that but it doesn't work as is.  What modifications do I need to make for this to work?
dt << select column group( common );
Slán
SpannerHead
SpannerHead
Re: Select column group from a list
Ignore me!  Figured it out.  Duh!
For( g = 1, g <= N Items( common ), g++,
    dt << select column group( common[g] )
Slán
SpannerHead
You can also use list with select column group but you have to evaluate it
dt = Open("$SAMPLE_DATA/Cities.jmp");
dt << group columns("xy", {:X, :y});
dt << group columns("pollutants", :Ozone :: :Lead);
groupnames = {"xy", "pollutants"};
Eval(EvalExpr(dt << select column group(Expr(groupnames))));
SpannerHead
Slán
SpannerHead
