New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
Allow secondary or alternate column names import a column measurement16443_GdfgDFGDD_Vf_XXX_A16 - and plot it as Vf(2mA) ... with the possibility to get it updated by from a file with column name measurement16443_GdfgDFGDD_Vf_XXX_A16
Map Shapes facilitate the generation of wafermaps. But there are also some disadvantages: complicated to use, no possibility to flip a wafer (reverse one axis, but not the other one), one has to share 3 files instead of one ...
Re: collection of wishes with focus on "Semiconductor"
Created:
Jun 20, 2024 02:51 PM
| Last Modified: Feb 17, 2026 10:01 AM(7020 views)
| Posted in reply to message from hogi 06-17-2024
Did you ever want to select TWO lots from a long list? Then you know this problem: Have data filter selection not clear when you need to enter a new filtering item
Column Quick Swapper: toggle between current OR voltage OR current+voltage on the Y axis ... instead of replacing current in all roles by voltage (Column Switcher)
