Semiconductor JMP Users Group Discussions
Level XIII
collection of wishes with focus on "Semiconductor"
New features or bug fixes that help one user in one area might also help other users in the same area.
So I thought about creating a list of feature requests with a focus on Semiconductor.
Let's join forces to get them implemented as soon as possible : )
the idea:
  • a link - and maybe a short motivation here
  • to keep the list "slim", if you have any comments, please follow the link and comment in the original post
27 REPLIES 27
Level XIII
Re: collection of wishes with focus on "Semiconductor"
Add CDFs to Graph Builder
- Cumulative Probability is now possible via  scoping ☞ JMP19
- CDF was/is possible in Graph Builder, but the first step is missing (->  wish)
Level XIII
Add normalization and robust statistical functions (and matrix functions)
+ harmonize (!) the aggregation functions which are available at different places in JMP:
  • Tables/Summary
  • Graph Builder
  • JSL aggregation functions (Col ...)
  • header statistics (the new benchmark : )
Level XIII
Level XIII
Column Property - inclusive Values
- the topic was discussed during the Semiconductor Lunch @ Discovery-Summit Europe 2024
- now available in JMP19
Level XIII
Line annotation - option to generate linecut plot
- available via  Graph Builder Toolbar @hogi / Marketplace
Level XIII
Allow secondary or alternate column names
import a column measurement16443_GdfgDFGDD_Vf_XXX_A16  - and plot it as Vf(2mA)
... with the possibility to get it updated by from a file with column name  measurement16443_GdfgDFGDD_Vf_XXX_A16
Level XIII
Map Shapes facilitate the generation of wafermaps.
But there are also some disadvantages: complicated to use, no possibility to flip a wafer (reverse one axis, but not the other one), one has to share 3 files instead of one ...
Heatmaps can be used as an alternative - but they have their own drawback:
 Heatmap - option: fixed Tick spacing (aggregation area)
Level XIII
Did you ever want to select TWO lots from a long list?
Then you know this problem:
Have data filter selection not clear when you need to enter a new filtering item
- available now in JMP19
Level XIII
JSL bit operations
  • Native function for bit operations like XOR, shift bits, split bits, get bit, set bit.
Level XIII
Add new switcher called Role Switcher
Column Quick Swapper: toggle between current OR voltage OR current+voltage on the Y axis
... instead of replacing current in all roles by voltage (Column Switcher)
Level XIII
Meaningful plots - despite the broken devices with 5V (compliance) and 0A current:
Graph Builder Preferences: Middle 90% (or 99%)
Level XIII
live view for gradient settings
Level XIII
Count:
"how many wafers" [in this list of chips]
"how many batches" [in this list of wafers]
new JSL function: Col N Categories
-> available now as Col N Unique()
Add dense ranking to Ranking Tie and Col Rank functions
-> available now as Col Score()
Level XIII
how often do you ask per day: is in spec(value)
surprising: there is no official way yet to ask JMP ...
please support  is in spec (value) with a Kudo
... and add your comments how to further enrich the functionality.
