JMP Wish List
Have data filter selections not clear when you need to enter a new filtering item
What inspired this wish list request? When I need to filter multiple items in a list it is great to be able to type in the main portion of the "item" so that the filter only shows relevant items.  However, when I then go to filter additional items and thus clear the filter text box when I type in a new main portion of an item into the filter text box it resets the selections.
In this example I want to select all names starting with C and J.  So I start with c's:
clear the filter text box and so far so good....
Then go to J's:
and now my c's are no longer selected...
What is the improvement you would like to see? Please allow the ability for the previously selected items to not be cleared, thus the change in filtered items can be additive.
Why is this idea important? This will speed up the process of filtering columns with lots of levels that are not in easy to find blocks.
10 Comments
Level XIII
Thumbs up.
With current jmp, you just have once the chance to use the joker "filter the list" - use it wisely for your first selection.
All additional selections have to be done without using the filter.
tztztz
Level XIII
same issue for column names - I tried it with CTRL, I tried it with SHIFT, no success.
once you use the filter, the previous column selection gets lost:
(view in My Videos)
shampton82
Level VIII
@hogi so sad............
Level XIII
Sarah-Sylvestre
Level XIII
Thanks.
Will help a lot!
several colleagues asked for a solution or workaround.
In our case: a list of e.g. 100 - 1000 lots with cryptic names.
A34432VHFG2
H35453vBBGD
The user has to interactively select 4 of them via the local data filter to adjust the analysis.
Level XIII
duplicate wish by @JMP-Andy
Sarah-Sylvestre
Status changed to: Yes, Stay Tuned!
This will be available in JMP 19.
Level XIII
wonderful, thanks!
Will improve the usability of the Data Filter significantly for us : )
Sarah-Sylvestre
Status changed to: Delivered
