  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Recode and Recode Column Names: apply for specific rows/columns
The Filter menu in the column list is very useful. The user just has to add tiny identifiers to the column names to get a handle to select a set of columns (much more flexible that grouping :).
For larger data tables, it could help to have an automatic way to add strings to column names.
What is possible at the moment:
- use JSL: https://community.jmp.com/t5/Discussions/Append-a-string-to-column-names/m-p/614825/highlight/true#M...
- use Rename Columns from the Jmp Scripting tools Add-In: https://community.jmp.com/t5/Discussions/Append-a-string-to-column-names/m-p/614760/highlight/true#M...
Unfortunately, the two approaches are not recorded in Workflow Builder. The user has to script on his own.
@Jed_Campbell found a very creative way to achieve the task with steps which are recorder by Workflow Builder:
https://community.jmp.com/t5/Discussions/Append-a-string-to-column-names/m-p/614826/highlight/true#M...
This is can be seen as a proof that "actually it is possible" - but less as a viable way which you would suggest your colleagues after 2 weeks with Jmp.
So, under the line, at the moment there is no easy way to achieve the task.
Please steal some ideas from Scripting Tools /Rename Columns  and add them to std. Jmp.
especially:
A similar option could also be added to the Recode function -.
Why is this idea important?
It's not - just an improvement of Jmp which will help the users to change column names and entries in a more flexible way.
3 Comments
hogi
Level XIII
@hogi wrote:
A similar option could also be added to the Recode function - to recode just the selected row entries.
Workaround to just apply a Recode to selected row entries:
- select the rows
- open a Subset for the selected rows
- apply Recode to the Subset
Concerning Recoding selected column names, this approach doesn't work
- unfortunately, Recode Column Names is disabled for linked subsets.
Along this line, manual editing of the column name is also disabled:
hogi
Level XIII
@Sarah-Sylvestre .
a)  for rename selected rows, with the workaround there is no need anymore for an improvement
b)  the case with "rename selected columns" is quite rare
-> wish can be archived.
just noticed: b) in the queue - thanks
hogi
Level XIII
@Sarah-Sylvestre
so, can be set to "in the queue" :)
