  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Conditionnal factors
We often deal with multi-step process optimization problems. For each step it is possible to use different technologies that have different factors or to simply bypass a step.
In the diagram below, the first step can be avoided. In this case (Step 1 == "None"), it is imperative that the answer does not depend on solvent, time or temperature. For the second step, the Power must not influence the response if Step 2 == "A" (respectively for Mixing and Step 2 == "B").
This same kind of situation can be found in the case where we want to optimize both the quantity and the type of an ingredient (see https://community.jmp.com/t5/Discussions/How-do-I-indicate-that-a-mixture-factor-can-take-a-number-o...)
The ideal would be if JMP allows to specify "conditionnal factors" when setting a model both in the DoE and Fit Model plateform. It could be similar to nested factors.
Why is this idea important?
Dealing with this kind of constraint could be done using a specific coding. That would avoid the user to implement the tricky solution proposed in the post quoted above.
