The Filter menu in the column list is very useful. The user just has to add tiny identifiers to the column names to get a handle to select a set of columns (much more flexible that grouping :).
For larger data tables, it could help to have an automatic way to add strings to column names.
What is possible at the moment:
- use JSL: https://community.jmp.com/t5/Discussions/Append-a-string-to-column-names/m-p/614825/highlight/true#M...
- use Rename Columns from the Jmp Scripting tools Add-In: https://community.jmp.com/t5/Discussions/Append-a-string-to-column-names/m-p/614760/highlight/true#M...
Unfortunately, the two approaches are not recorded in Workflow Builder. The user has to script on his own.
@Jed_Campbell found a very creative way to achieve the task with steps which are recorder by Workflow Builder:
https://community.jmp.com/t5/Discussions/Append-a-string-to-column-names/m-p/614826/highlight/true#M...
This is can be seen as a proof that "actually it is possible" - but less as a viable way which you would suggest your colleagues after 2 weeks with Jmp.
So, under the line, at the moment there is no easy way to achieve the task.
Please steal some ideas from Scripting Tools /Rename Columns and add them to std. Jmp.
especially:
A similar option could also be added to the Recode function -.
Why is this idea important?
It's not - just an improvement of Jmp which will help the users to change column names and entries in a more flexible way.
more wishes submitted by
