%3CLINGO-SUB%20id%3D%22lingo-sub-55175%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EDeseabilidades%20del%20conjunto%20de%20perfiles%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-55175%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EHola%2C%3C%2FP%3E%0A%3CP%3EEstoy%20mirando%20el%20tri%C3%A1ngulo%20rojo%20del%20Profiler%2C%20en%20Optimizaci%C3%B3n%20y%20deseabilidad%20-%26gt%3B%20Establecer%20deseabilidades.%3C%2FP%3E%0A%3CP%3EMuchos%20de%20nuestros%20usuarios%20m%C3%A1s%20nuevos%20se%20confunden%20cuando%20tienen%20m%C3%BAltiples%20variables%20y%20porque%20JMP%20muestra%20un%20cuadro%20modal%20independiente%20para%20establecer%20la%20conveniencia%20de%20cada%20respuesta%2C%20una%20a%20la%20vez.%20Los%20m%C3%A1s%20astutos%20notan%20que%20cada%20cuadro%20es%20para%20una%20respuesta%20diferente%2C%20pero%20otros%20no%20notan%20el%20cambio%20sutil.%3C%2FP%3E%0A%3CP%3E%C2%BFHay%20alguna%20forma%20de%20reemplazar%20esta%20interfaz%20con%20una%20sola%20ventana%3F%20Utilice%20un%20cuadro%20de%20lista%2C%20un%20cuadro%20combinado%20o%20un%20cuadro%20de%20pesta%C3%B1as%20para%20organizar%20las%20diferentes%20respuestas.%20Luego%2C%20el%20usuario%20puede%20ir%20a%20%22Establecer%20opciones%20deseables%22%2C%20ver%20todas%20las%20respuestas%20en%20una%20ventana%20y%2C%20potencialmente%2C%20configurarlas%20todas%20desde%20la%20misma%20ventana.%20O%2C%20con%20la%20flexibilidad%20de%20elegir%20qu%C3%A9%20respuestas%20deben%20configurarse%2C%20tener%20una%20propiedad%20%22seleccionar%20la%20respuesta%20a%20cambiar%22%20le%20permite%20al%20usuario%20omitir%20dos%20o%20tres%20respuestas%20que%20no%20necesitan%20cambiarse%20en%20primer%20lugar.%3C%2FP%3E%0A%3CP%3ELa%20guinda%20del%20pastel%3A%20permitir%20tambi%C3%A9n%20alg%C3%BAn%20tipo%20de%20opci%C3%B3n%20de%20%22Estandarizar%20lo%20deseable%22%20desde%20el%20generador%20de%20perfiles.%20Claro%2C%20puedes%20estandarizar%20atributos%20de%20la%20tabla%20de%20datos%20y%20configurar%20la%20propiedad%20L%C3%ADmites%20de%20respuesta%2C%20pero%20cuando%20est%C3%A1s%20en%20medio%20de%20un%20generador%20de%20perfiles%20eso%20no%20es%20intuitivo.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-55175%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ECombinaci%C3%B3n%20y%20limpieza%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-55213%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Deseabilidades%20del%20conjunto%20Profiler%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-55213%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDe%20acuerdo%2C%20CTRL-clic%20es%20%C3%BAtil%20(y%20se%20lo%20muestro%20a%20los%20nuevos%20usuarios)%2C%20simplemente%20tienen%20problemas%20para%20recordarlo.%20Gracias.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-55198%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Deseabilidades%20del%20conjunto%20Profiler%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-55198%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ENo%20estoy%20en%20desacuerdo%20con%20tu%20lista%20de%20deseos.%20Esta%20es%20solo%20una%20sugerencia%20que%20podr%C3%ADa%20ayudar%20mientras%20tanto.%3C%2FP%3E%3CP%3EHaga%20que%20el%20usuario%20seleccione%20Funciones%20de%20deseabilidad.Luego%20p%C3%ADdales%20CTRL%20%2B%20clic%20en%20cada%20gr%C3%A1fico%20de%20deseabilidad.%20Hace%20que%20sea%20un%20poco%20m%C3%A1s%20f%C3%A1cil%20darse%20cuenta%20de%20qu%C3%A9%20respuesta%20se%20est%C3%A1%20optimizando.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOtra%20opci%C3%B3n%20es%20configurar%20la%20Deseabilidad%20a%20trav%C3%A9s%20de%20la%20interfaz%20de%20la%20columna%2C%20una%20columna%20a%20la%20vez%3A%20seleccione%20una%20columna%20de%20respuesta%2C%20haga%20clic%20con%20el%20bot%C3%B3n%20derecho%2C%20seleccione%20Propiedades%20de%20columna%2C%20seleccione%20L%C3%ADmite%20de%20respuesta%2C%20las%20Deseabilidades%20se%20pueden%20configurar%20desde%20esta%20interfaz.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EPero%20estoy%20de%20acuerdo%20en%20que%20ser%C3%ADa%20bueno%20un%20m%C3%A9todo%20m%C3%A1s%20f%C3%A1cil%20de%20configurar%20a%20trav%C3%A9s%20de%20una%20tabla.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3ENames%20Default%20To%20Here(%201%20)%3B%0Adt%20%3D%20Open(%20%22%24SAMPLE_DATA%2FTiretread.jmp%22%20)%3B%0Aobj%20%3D%20Profiler(%0A%20Y(%0A%20%20%3APred%20Formula%20ABRASION%2C%0A%20%20%3APred%20Formula%20MODULUS%2C%0A%20%20%3APred%20Formula%20ELONG%2C%0A%20%20%3APred%20Formula%20HARDNESS%0A%20)%0A)%3B%0Aobj%20%26lt%3B%26lt%3B%20Desirability%20Functions(%201%20)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E
View Original Published Thread
Deseabilidades del conjunto de perfiles
Hola,
Estoy mirando el triángulo rojo del Profiler, en Optimización y deseabilidad -> Establecer deseabilidades.
Muchos de nuestros usuarios más nuevos se confunden cuando tienen múltiples variables y porque JMP muestra un cuadro modal independiente para establecer la conveniencia de cada respuesta, una a la vez. Los más astutos notan que cada cuadro es para una respuesta diferente, pero otros no notan el cambio sutil.
¿Hay alguna forma de reemplazar esta interfaz con una sola ventana? Utilice un cuadro de lista, un cuadro combinado o un cuadro de pestañas para organizar las diferentes respuestas. Luego, el usuario puede ir a "Establecer opciones deseables", ver todas las respuestas en una ventana y, potencialmente, configurarlas todas desde la misma ventana. O, con la flexibilidad de elegir qué respuestas deben configurarse, tener una propiedad "seleccionar la respuesta a cambiar" le permite al usuario omitir dos o tres respuestas que no necesitan cambiarse en primer lugar.
La guinda del pastel: permitir también algún tipo de opción de "Estandarizar lo deseable" desde el generador de perfiles. Claro, puedes estandarizar atributos de la tabla de datos y configurar la propiedad Límites de respuesta, pero cuando estás en medio de un generador de perfiles eso no es intuitivo.
Esta publicación fue escrita originalmente en English (US) y ha sido traducida para su conveniencia. Cuando responda, también se traducirá a English (US).
2 Comments
gzmorgan0
Super User (Alumni)
No estoy en desacuerdo con tu lista de deseos. Esta es solo una sugerencia que podría ayudar mientras tanto.
Haga que el usuario seleccione Funciones de deseabilidad.Luego pídales CTRL + clic en cada gráfico de deseabilidad. Hace que sea un poco más fácil darse cuenta de qué respuesta se está optimizando.
Otra opción es configurar la Deseabilidad a través de la interfaz de la columna, una columna a la vez: seleccione una columna de respuesta, haga clic con el botón derecho, seleccione Propiedades de columna, seleccione Límite de respuesta, las Deseabilidades se pueden configurar desde esta interfaz.
Pero estoy de acuerdo en que sería bueno un método más fácil de configurar a través de una tabla.
Names Default To Here( 1 );
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
obj = Profiler(
 Y(
  :Pred Formula ABRASION,
  :Pred Formula MODULUS,
  :Pred Formula ELONG,
  :Pred Formula HARDNESS
obj << Desirability Functions( 1 );
mjoner
Level VI
De acuerdo, CTRL-clic es útil (y se lo muestro a los nuevos usuarios), simplemente tienen problemas para recordarlo. Gracias.
