Mean comparison wizard with hints like in the Easy DOE platform
Status Quo: Questions while comparing means in the Fit Y by X platform (Oneway analysis):
  • Which test do I pick for my data?
  • What are the conditions that have to be fulfilled to use the test?
Idea of the wizard:
  • Overview over all tests with some little hints
  • Picking several tests and see the results in the same window, side by side
  • Additional to the tables and evaluations: short conclusion (“Means of Group A and Group B are / are not significantly different from each other”) or hint (“p-value is x which means the means are / are not significantly different from each other”)
Why is this idea important:
  • Helps to see all the opportunities and not always sticking to (maybe in some case a false!) test
  • All tests in one platform
