%3CLINGO-SUB%20id%3D%22lingo-sub-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAsistente%20de%20comparaci%C3%B3n%20de%20medias%20con%20sugerencias%20como%20en%20la%20plataforma%20Easy%20DOE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CEM%3EStatus%20Quo%3A%20Preguntas%20al%20comparar%20medias%20en%20la%20plataforma%20Fit%20Y%20by%20X%20(an%C3%A1lisis%20Oneway)%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3E%C2%BFQu%C3%A9%20prueba%20elijo%20para%20mis%20datos%3F%20%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3E%C2%BFCu%C3%A1les%20son%20las%20condiciones%20que%20deben%20cumplirse%20para%20utilizar%20la%20prueba%3F%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EIdea%20del%20asistente%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EDescripci%C3%B3n%20general%20de%20todas%20las%20pruebas%20con%20algunos%20peque%C3%B1os%20consejos.%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3ESeleccionar%20varias%20pruebas%20y%20ver%20los%20resultados%20en%20la%20misma%20ventana%2C%20una%20al%20lado%20de%20la%20otra%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EAdem%C3%A1s%20de%20las%20tablas%20y%20evaluaciones%3A%20conclusi%C3%B3n%20breve%20(%E2%80%9CLas%20medias%20del%20grupo%20A%20y%20del%20grupo%20B%20son%2Fno%20son%20significativamente%20diferentes%20entre%20s%C3%AD%E2%80%9D)%20o%20sugerencia%20(%E2%80%9Cel%20valor%20p%20es%20x%2C%20lo%20que%20significa%20que%20las%20medias%20son%2Fno%20son%20significativamente%20diferentes%20entre%20s%C3%AD%E2%80%9D)%20otro%22)%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EAyuda%20a%20ver%20todas%20las%20oportunidades%20y%20no%20siempre%20apegarse%20a%20una%20prueba%20(%C2%A1tal%20vez%20en%20alg%C3%BAn%20caso%20falsa!).%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3ETodas%20las%20pruebas%20en%20una%20plataforma%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3ECompartir%20y%20comunicar%20resultados%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Mean comparison wizard with hints like in the Easy DOE platform
Status Quo: Questions while comparing means in the Fit Y by X platform (Oneway analysis):
  • Which test do I pick for my data?
  • What are the conditions that have to be fulfilled to use the test?
Idea of the wizard:
  • Overview over all tests with some little hints
  • Picking several tests and see the results in the same window, side by side
  • Additional to the tables and evaluations: short conclusion (“Means of Group A and Group B are / are not significantly different from each other”) or hint (“p-value is x which means the means are / are not significantly different from each other”)
Why is this idea important:
  • Helps to see all the opportunities and not always sticking to (maybe in some case a false!) test
  • All tests in one platform
