%3CLINGO-SUB%20id%3D%22lingo-sub-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EMean%20comparison%20wizard%20with%20hints%20like%20in%20the%20Easy%20DOE%20platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CEM%3EStatus%20Quo%3A%20Questions%20while%20comparing%20means%20in%20the%20Fit%20Y%20by%20X%20platform%20(Oneway%20analysis)%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EWhich%20test%20do%20I%20pick%20for%20my%20data%3F%20%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EWhat%20are%20the%20conditions%20that%20have%20to%20be%20fulfilled%20to%20use%20the%20test%3F%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EIdea%20of%20the%20wizard%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EOverview%20over%20all%20tests%20with%20some%20little%20hints%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EPicking%20several%20tests%20and%20see%20the%20results%20in%20the%20same%20window%2C%20side%20by%20side%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EAdditional%20to%20the%20tables%20and%20evaluations%3A%20short%20conclusion%20(%E2%80%9CMeans%20of%20Group%20A%20and%20Group%20B%20are%20%2F%20are%20not%20significantly%20different%20from%20each%20other%E2%80%9D)%20or%20hint%20(%E2%80%9Cp-value%20is%20x%20which%20means%20the%20means%20are%20%2F%20are%20not%20significantly%20different%20from%20each%20other%E2%80%9D)%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EWhy%20is%20this%20idea%20important%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EHelps%20to%20see%20all%20the%20opportunities%20and%20not%20always%20sticking%20to%20(maybe%20in%20some%20case%20a%20false!)%20test%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EAll%20tests%20in%20one%20platform%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3ESharing%20and%20Communicating%20Results%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Mean comparison wizard with hints like in the Easy DOE platform
Status Quo: Questions while comparing means in the Fit Y by X platform (Oneway analysis):
  • Which test do I pick for my data?
  • What are the conditions that have to be fulfilled to use the test?
Idea of the wizard:
  • Overview over all tests with some little hints
  • Picking several tests and see the results in the same window, side by side
  • Additional to the tables and evaluations: short conclusion (“Means of Group A and Group B are / are not significantly different from each other”) or hint (“p-value is x which means the means are / are not significantly different from each other”)
Why is this idea important:
  • Helps to see all the opportunities and not always sticking to (maybe in some case a false!) test
  • All tests in one platform
