%3CLINGO-SUB%20id%3D%22lingo-sub-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EMittelwertvergleichsassistent%20mit%20Hinweisen%20wie%20in%20der%20Easy%20DOE-Plattform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CEM%3EStatus%20Quo%3A%20Fragen%20beim%20Mittelwertvergleich%20in%20der%20Fit%20Y%20by%20X-Plattform%20(Oneway-Analyse)%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EWelchen%20Test%20w%C3%A4hle%20ich%20f%C3%BCr%20meine%20Daten%3F%20%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EWelche%20Voraussetzungen%20m%C3%BCssen%20f%C3%BCr%20die%20Nutzung%20des%20Tests%20erf%C3%BCllt%20sein%3F%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EIdee%20des%20Zauberers%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3E%C3%9Cbersicht%20aller%20Tests%20mit%20einigen%20kleinen%20Hinweisen%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EW%C3%A4hlen%20Sie%20mehrere%20Tests%20aus%20und%20sehen%20Sie%20sich%20die%20Ergebnisse%20im%20selben%20Fenster%20nebeneinander%20an%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EZus%C3%A4tzlich%20zu%20den%20Tabellen%20und%20Auswertungen%3A%20kurze%20Schlussfolgerung%20(%E2%80%9EDie%20Mittelwerte%20der%20Gruppe%20A%20und%20der%20Gruppe%20B%20sind%2Fsind%20nicht%20signifikant%20unterschiedlich%20voneinander%E2%80%9C)%20oder%20Hinweis%20(%E2%80%9Ep-Wert%20ist%20x%2C%20was%20bedeutet%2C%20dass%20die%20Mittelwerte%20jeweils%20voneinander%20abweichen%2Fsind%2Fsind).%20andere%22)%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EWarum%20ist%20diese%20Idee%20wichtig%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EHilft%2C%20alle%20M%C3%B6glichkeiten%20zu%20erkennen%20und%20sich%20nicht%20immer%20an%20einen%20(vielleicht%20in%20manchen%20F%C3%A4llen%20falschen!)%20Test%20zu%20halten%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EAlle%20Tests%20auf%20einer%20Plattform%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EErgebnisse%20teilen%20und%20kommunizieren%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Mean comparison wizard with hints like in the Easy DOE platform
Status Quo: Questions while comparing means in the Fit Y by X platform (Oneway analysis):
  • Which test do I pick for my data?
  • What are the conditions that have to be fulfilled to use the test?
Idea of the wizard:
  • Overview over all tests with some little hints
  • Picking several tests and see the results in the same window, side by side
  • Additional to the tables and evaluations: short conclusion (“Means of Group A and Group B are / are not significantly different from each other”) or hint (“p-value is x which means the means are / are not significantly different from each other”)
Why is this idea important:
  • Helps to see all the opportunities and not always sticking to (maybe in some case a false!) test
  • All tests in one platform
