%3CLINGO-SUB%20id%3D%22lingo-sub-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAssistant%20de%20comparaison%20moyenne%20avec%20des%20astuces%20comme%20dans%20la%20plateforme%20Easy%20DOE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CEM%3EStatus%20Quo%20%3A%20Questions%20lors%20de%20la%20comparaison%20des%20moyennes%20dans%20la%20plateforme%20Fit%20Y%20by%20X%20(analyse%20Oneway)%20%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EQuel%20test%20dois-je%20choisir%20pour%20mes%20donn%C3%A9es%26nbsp%3B%3F%20%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EQuelles%20sont%20les%20conditions%20%C3%A0%20remplir%20pour%20utiliser%20le%20test%20%3F%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EId%C3%A9e%20du%20sorcier%20%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EAper%C3%A7u%20de%20tous%20les%20tests%20avec%20quelques%20petites%20astuces%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EChoisir%20plusieurs%20tests%20et%20voir%20les%20r%C3%A9sultats%20dans%20la%20m%C3%AAme%20fen%C3%AAtre%2C%20c%C3%B4te%20%C3%A0%20c%C3%B4te%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EEn%20plus%20des%20tableaux%20et%20des%20%C3%A9valuations%20%3A%20courte%20conclusion%20(%C2%AB%20Les%20moyennes%20du%20groupe%20A%20et%20du%20groupe%20B%20sont%2Fne%20sont%20pas%20significativement%20diff%C3%A9rentes%20les%20unes%20des%20autres%20%C2%BB)%20ou%20indice%20(%C2%AB%20La%20valeur%20p%20est%20x%2C%20ce%20qui%20signifie%20que%20les%20moyennes%20sont%2Fne%20sont%20pas%20significativement%20diff%C3%A9rentes%20les%20unes%20des%20autres)%20autre%22)%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EPourquoi%20cette%20id%C3%A9e%20est-elle%20importante%26nbsp%3B%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EPermet%20de%20voir%20toutes%20les%20opportunit%C3%A9s%20et%20de%20ne%20pas%20toujours%20s'en%20tenir%20au%20test%20(peut-%C3%AAtre%20dans%20certains%20cas%20un%20faux%20!)%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3ETous%20les%20tests%20sur%20une%20seule%20plateforme%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EPartager%20et%20communiquer%20les%20r%C3%A9sultats%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Mean comparison wizard with hints like in the Easy DOE platform
Status Quo: Questions while comparing means in the Fit Y by X platform (Oneway analysis):
  • Which test do I pick for my data?
  • What are the conditions that have to be fulfilled to use the test?
Idea of the wizard:
  • Overview over all tests with some little hints
  • Picking several tests and see the results in the same window, side by side
  • Additional to the tables and evaluations: short conclusion (“Means of Group A and Group B are / are not significantly different from each other”) or hint (“p-value is x which means the means are / are not significantly different from each other”)
Why is this idea important:
  • Helps to see all the opportunities and not always sticking to (maybe in some case a false!) test
  • All tests in one platform
