%3CLINGO-SUB%20id%3D%22lingo-sub-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EProcedura%20guidata%20per%20il%20confronto%20delle%20medie%20con%20suggerimenti%20come%20nella%20piattaforma%20Easy%20DOE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CEM%3EStatus%20Quo%3A%20domande%20durante%20il%20confronto%20delle%20medie%20nella%20piattaforma%20Fit%20Y%20by%20X%20(analisi%20unidirezionale)%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EQuale%20test%20scelgo%20per%20i%20miei%20dati%3F%20%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EQuali%20sono%20le%20condizioni%20che%20devono%20essere%20soddisfatte%20per%20utilizzare%20il%20test%3F%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EIdea%20del%20mago%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EPanoramica%20di%20tutti%20i%20test%20con%20alcuni%20piccoli%20suggerimenti%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EScegli%20diversi%20test%20e%20visualizza%20i%20risultati%20nella%20stessa%20finestra%2C%20fianco%20a%20fianco%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3EIn%20aggiunta%20alle%20tabelle%20e%20alle%20valutazioni%3A%20breve%20conclusione%20(%22Le%20medie%20del%20Gruppo%20A%20e%20del%20Gruppo%20B%20sono%2Fnon%20sono%20significativamente%20diverse%20l'una%20dall'altra%22)%20o%20suggerimento%20(%22il%20valore%20p%20%C3%A8%20x%2C%20il%20che%20significa%20che%20le%20medie%20sono%2Fnon%20sono%20significativamente%20diverse%20l'una%20dall'altra%22)%20altro%22)%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CEM%3EPerch%C3%A9%20questa%20idea%20%C3%A8%20importante%3A%3C%2FEM%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CEM%3EAiuta%20a%20vedere%20tutte%20le%20opportunit%C3%A0%20e%20a%20non%20attenersi%20sempre%20al%20test%20(forse%20in%20alcuni%20casi%20falso!).%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3ETutti%20i%20test%20in%20un'unica%20piattaforma%3C%2FEM%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-622912%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3ECondivisione%20e%20comunicazione%20dei%20risultati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Mean comparison wizard with hints like in the Easy DOE platform
Status Quo: Questions while comparing means in the Fit Y by X platform (Oneway analysis):
  • Which test do I pick for my data?
  • What are the conditions that have to be fulfilled to use the test?
Idea of the wizard:
  • Overview over all tests with some little hints
  • Picking several tests and see the results in the same window, side by side
  • Additional to the tables and evaluations: short conclusion (“Means of Group A and Group B are / are not significantly different from each other”) or hint (“p-value is x which means the means are / are not significantly different from each other”)
Why is this idea important:
  • Helps to see all the opportunities and not always sticking to (maybe in some case a false!) test
  • All tests in one platform
