%3CLINGO-SUB%20id%3D%22lingo-sub-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%C3%84ndern%20Sie%20die%20Schriftart%20(Gr%C3%B6%C3%9Fe)%20beim%20Gruppieren%20von%20Variablen%20im%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EWenn%20Sie%20im%20Graph%20Builder%20eine%20Gruppierungsvariable%20verwenden%2C%20kann%20die%20Schriftgr%C3%B6%C3%9Fe%20der%20Beschriftung%20nicht%20einfach%20ge%C3%A4ndert%20werden.%20Die%20einzige%20Methode%2C%20die%20ich%20gefunden%20habe%2C%20besteht%20darin%2C%20die%20allgemeine%20%22Text%22%20-Schriftgr%C3%B6%C3%9Fe%20im%20Men%C3%BC%20%22Einstellungen%22%20zu%20%C3%A4ndern.%20Dies%20ist%20aus%202%20Gr%C3%BCnden%20nicht%20praktikabel%3A%3C%2FP%3E%3CP%3E-%20Es%20%C3%A4ndert%20die%20Einstellungen%20der%20gesamten%20Software%2C%20sodass%20dies%20nicht%20Diagramm%20f%C3%BCr%20Diagramm%20erfolgen%20kann%3C%2FP%3E%3CP%3E-%20Da%20die%20Schriftgr%C3%B6%C3%9Fe%20%22Text%22%20sehr%20allgemein%20ist%2C%20trifft%20sie%20auf%20VIELE%20Elemente%20in%20der%20Software%20zu.%20Wenn%20Sie%20jemals%20versucht%20haben%2C%20es%20zu%20%C3%A4ndern%2C%20bringt%20es%20alle%20Ihre%20Fenster%2C%20Diagramme%20usw.%20durcheinander%20und%20macht%20sie%20unbrauchbar.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIch%20m%C3%B6chte%20also%20anfordern%2C%20dass%20dies%20ver%C3%A4nderbar%20ist%2C%20genau%20wie%20f%C3%BCr%20die%20X-%20und%20Y-Achse.%20Wenn%20wir%20schon%20dabei%20sind%2C%20haben%20Sie%20die%20gleichen%20Beschriftungsoptionen%20wie%20f%C3%BCr%20die%20anderen%20Achsen%2C%20wie%20Ausrichtung%20usw.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EGrafik%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EBenutzeroberfl%C3%A4che%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-520380%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Schriftart%20(Gr%C3%B6%C3%9Fe)%20beim%20Gruppieren%20von%20Variablen%20im%20Graph%20Builder%20%C3%A4ndern%20-%20Status%20ge%C3%A4ndert%20in%3A%20Duplizieren%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-520380%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-244754%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Schriftart%20(Gr%C3%B6%C3%9Fe)%20beim%20Gruppieren%20von%20Variablen%20im%20Graph%20Builder%20%C3%A4ndern%20-%20Status%20ge%C3%A4ndert%20in%3A%20Archiviert%20-%20Duplizieren%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-244754%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDies%20ist%20ein%20Duplikat%20von%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FRight-click-to-change-Group-font-and-font-size%2Fm-p%2F116638%23U116638%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%20Klicken%20Sie%20mit%20der%20rechten%20Maustaste%2C%20um%20Schriftart%20und%20Schriftgr%C3%B6%C3%9Fe%20der%20Gruppe%20zu%20%C3%A4ndern%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-233777%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20%C3%84ndern%20Sie%20die%20Schriftart%20(Gr%C3%B6%C3%9Fe)%20beim%20Gruppieren%20von%20Variablen%20im%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-233777%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIch%20hatte%20die%20gleichen%20Schwierigkeiten%20mit%20Group%20Fonts%20im%20Graph%20Builder.%20Der%20beste%20Workaround%20f%C3%BCr%20mich%20ist%3CSPAN%3E%20STRG%20SHIFT%20%2B%20um%20alles%20in%20JMP%20zu%20vergr%C3%B6%C3%9Fern%2C%20kopieren%2Feinf%C3%BCgen%2C%20dann%20alles%20wieder%20verkleinern%20mit%20STRG%20SHIFT%20-.%20Funktioniert%20unter%20Windows%2C%20nicht%20sicher%20f%C3%BCr%20Mac.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIn%20eine%20%C3%A4hnliche%20Richtung%20geht%20folgender%20Wunsch%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FFont-Table-in-Graph-Builder-to-quickly-change-Font-settings-for%2Fidi-p%2F51365%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FFont-Table-in-Graph-Builder-to-quickly-change-Font-settings-for%2Fidi-p%2F51365%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
Change Font (Size) on grouping variables in graph builder
In the graph builder, when using a grouping variable, the Font Size of the label can't be changed easily. The only method I found is to change the general "text" font size in the Preferences menu. This is impractical for 2 reasons :
- it changes the settings on the whole software so it can't be done graph by graph
-  as the "text" font size is very general, it applies to A LOT of items in the software. If you have ever tried changing it, it messes up all your windows, graphs, etc, making them unusable.
So, I would like to request this to be changeable, just like for the X and Y axes. While we're at it, have the same label options as for the other axes, like orientation, etc.
3 Comments
gerd
Level V
I've had the same difficulties with Group Fonts in Graph Builder. The best workaround for me is CTRL SHIFT + to enlarge everything in JMP, copy/paste, then reduce everything again with CTRL SHIFT -. Works on windows, not sure for Mac.
The following wish goes in a similar direction:
https://community.jmp.com/t5/JMP-Wish-List/Font-Table-in-Graph-Builder-to-quickly-change-Font-settin...
Jeff_Perkinson
Community Manager
Status changed to: Archived - Duplicate
Ryan_Gilmore
Community Manager
Status changed to: Duplicate
