    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
Change Font (Size) on grouping variables in graph builder
In the graph builder, when using a grouping variable, the Font Size of the label can't be changed easily. The only method I found is to change the general "text" font size in the Preferences menu. This is impractical for 2 reasons :
- it changes the settings on the whole software so it can't be done graph by graph
-  as the "text" font size is very general, it applies to A LOT of items in the software. If you have ever tried changing it, it messes up all your windows, graphs, etc, making them unusable.
So, I would like to request this to be changeable, just like for the X and Y axes. While we're at it, have the same label options as for the other axes, like orientation, etc.
3 Comments
gerd
Level V
I've had the same difficulties with Group Fonts in Graph Builder. The best workaround for me is CTRL SHIFT + to enlarge everything in JMP, copy/paste, then reduce everything again with CTRL SHIFT -. Works on windows, not sure for Mac.
The following wish goes in a similar direction:
https://community.jmp.com/t5/JMP-Wish-List/Font-Table-in-Graph-Builder-to-quickly-change-Font-settin...
Jeff_Perkinson
Community Manager
Status changed to: Archived - Duplicate
Ryan_Gilmore
Community Manager
Status changed to: Duplicate
