%3CLINGO-SUB%20id%3D%22lingo-sub-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ECambiar%20fuente%20(tama%C3%B1o)%20al%20agrupar%20variables%20en%20el%20generador%20de%20gr%C3%A1ficos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EEn%20el%20generador%20de%20gr%C3%A1ficos%2C%20cuando%20se%20usa%20una%20variable%20de%20agrupaci%C3%B3n%2C%20el%20tama%C3%B1o%20de%20fuente%20de%20la%20etiqueta%20no%20se%20puede%20cambiar%20f%C3%A1cilmente.%20El%20%C3%BAnico%20m%C3%A9todo%20que%20encontr%C3%A9%20es%20cambiar%20el%20tama%C3%B1o%20de%20fuente%20general%20del%20%22texto%22%20en%20el%20men%C3%BA%20Preferencias.%20Esto%20no%20es%20pr%C3%A1ctico%20por%202%20razones%3A%3C%2FP%3E%3CP%3E-%20cambia%20la%20configuraci%C3%B3n%20de%20todo%20el%20software%20por%20lo%20que%20no%20se%20puede%20hacer%20gr%C3%A1fico%20por%20gr%C3%A1fico%3C%2FP%3E%3CP%3E-%20como%20el%20tama%C3%B1o%20de%20fuente%20del%20%22texto%22%20es%20muy%20general%2C%20se%20aplica%20a%20MUCHOS%20elementos%20del%20software.%20Si%20alguna%20vez%20ha%20intentado%20cambiarlo%2C%20estropea%20todas%20sus%20ventanas%2C%20gr%C3%A1ficos%2C%20etc.%2C%20haci%C3%A9ndolos%20inutilizables.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEntonces%2C%20me%20gustar%C3%ADa%20solicitar%20que%20esto%20sea%20modificable%2C%20al%20igual%20que%20para%20los%20ejes%20X%20e%20Y.%20Mientras%20estamos%20en%20eso%2C%20tenga%20las%20mismas%20opciones%20de%20etiqueta%20que%20para%20los%20otros%20ejes%2C%20como%20orientaci%C3%B3n%2C%20etc.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EGr%C3%A1ficos%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInterfaz%20de%20usuario%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-520380%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Cambiar%20fuente%20(tama%C3%B1o)%20al%20agrupar%20variables%20en%20el%20generador%20de%20gr%C3%A1ficos%20-%20Estado%20cambiado%20a%3A%20Duplicado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-520380%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-244754%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Cambiar%20fuente%20(tama%C3%B1o)%20al%20agrupar%20variables%20en%20el%20generador%20de%20gr%C3%A1ficos%20-%20Estado%20cambiado%20a%3A%20Archivado%20-%20Duplicado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-244754%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EEste%20es%20un%20duplicado%20de%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FRight-click-to-change-Group-font-and-font-size%2Fm-p%2F116638%23U116638%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%20Haga%20clic%20con%20el%20bot%C3%B3n%20derecho%20para%20cambiar%20la%20fuente%20del%20grupo%20y%20el%20tama%C3%B1o%20de%20la%20fuente%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-233777%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Cambiar%20fuente%20(tama%C3%B1o)%20al%20agrupar%20variables%20en%20el%20generador%20de%20gr%C3%A1ficos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-233777%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHe%20tenido%20las%20mismas%20dificultades%20con%20Group%20Fonts%20en%20Graph%20Builder.%20La%20mejor%20soluci%C3%B3n%20para%20m%C3%AD%20es%3CSPAN%3E%20CTRL%20SHIFT%20%2B%20para%20agrandar%20todo%20en%20JMP%2C%20copiar%2Fpegar%2C%20luego%20reducir%20todo%20nuevamente%20con%20CTRL%20SHIFT%20-.%20Funciona%20en%20Windows%2C%20no%20estoy%20seguro%20para%20Mac.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEl%20siguiente%20deseo%20va%20en%20una%20direcci%C3%B3n%20similar%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FFont-Table-in-Graph-Builder-to-quickly-change-Font-settings-for%2Fidi-p%2F51365%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FFont-Table-in-Graph-Builder-to-quickly-change-Font-settings-for%2Fidi-p%2F51365%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
Change Font (Size) on grouping variables in graph builder
In the graph builder, when using a grouping variable, the Font Size of the label can't be changed easily. The only method I found is to change the general "text" font size in the Preferences menu. This is impractical for 2 reasons :
- it changes the settings on the whole software so it can't be done graph by graph
-  as the "text" font size is very general, it applies to A LOT of items in the software. If you have ever tried changing it, it messes up all your windows, graphs, etc, making them unusable.
So, I would like to request this to be changeable, just like for the X and Y axes. While we're at it, have the same label options as for the other axes, like orientation, etc.
3 Comments
gerd
Level V
I've had the same difficulties with Group Fonts in Graph Builder. The best workaround for me is CTRL SHIFT + to enlarge everything in JMP, copy/paste, then reduce everything again with CTRL SHIFT -. Works on windows, not sure for Mac.
The following wish goes in a similar direction:
https://community.jmp.com/t5/JMP-Wish-List/Font-Table-in-Graph-Builder-to-quickly-change-Font-settin...
Jeff_Perkinson
Community Manager
Status changed to: Archived - Duplicate
Ryan_Gilmore
Community Manager
Status changed to: Duplicate
