In the graph builder, when using a grouping variable, the Font Size of the label can't be changed easily. The only method I found is to change the general "text" font size in the Preferences menu. This is impractical for 2 reasons :
- it changes the settings on the whole software so it can't be done graph by graph
- as the "text" font size is very general, it applies to A LOT of items in the software. If you have ever tried changing it, it messes up all your windows, graphs, etc, making them unusable.
So, I would like to request this to be changeable, just like for the X and Y axes. While we're at it, have the same label options as for the other axes, like orientation, etc.
