%3CLINGO-SUB%20id%3D%22lingo-sub-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ECambia%20carattere%20(dimensione)%20sul%20raggruppamento%20delle%20variabili%20nel%20generatore%20di%20grafici%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ENel%20generatore%20di%20grafici%2C%20quando%20si%20utilizza%20una%20variabile%20di%20raggruppamento%2C%20la%20dimensione%20del%20carattere%20dell'etichetta%20non%20pu%C3%B2%20essere%20modificata%20facilmente.%20L'unico%20metodo%20che%20ho%20trovato%20%C3%A8%20modificare%20la%20dimensione%20generale%20del%20carattere%20%22testo%22%20nel%20menu%20Preferenze.%20Questo%20non%20%C3%A8%20pratico%20per%202%20motivi%3A%3C%2FP%3E%3CP%3E-%20cambia%20le%20impostazioni%20su%20tutto%20il%20software%20quindi%20non%20pu%C3%B2%20essere%20fatto%20grafico%20per%20grafico%3C%2FP%3E%3CP%3E-%20poich%C3%A9%20la%20dimensione%20del%20carattere%20%22testo%22%20%C3%A8%20molto%20generica%2C%20si%20applica%20a%20MOLTI%20elementi%20nel%20software.%20Se%20hai%20mai%20provato%20a%20cambiarlo%2C%20rovina%20tutte%20le%20finestre%2C%20i%20grafici%2C%20ecc.%2C%20Rendendoli%20inutilizzabili.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EQuindi%2C%20vorrei%20richiedere%20che%20questo%20sia%20modificabile%2C%20proprio%20come%20per%20gli%20assi%20X%20e%20Y.%20Gi%C3%A0%20che%20ci%20siamo%2C%20disponi%20delle%20stesse%20opzioni%20di%20etichetta%20degli%20altri%20assi%2C%20come%20l'orientamento%2C%20ecc.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-233756%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EGrafica%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-520380%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Cambia%20carattere%20(dimensione)%20sul%20raggruppamento%20delle%20variabili%20nel%20generatore%20di%20grafici%20-%20Stato%20modificato%20in%3A%20Duplicato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-520380%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-244754%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Modifica%20carattere%20(dimensione)%20nel%20raggruppamento%20delle%20variabili%20nel%20generatore%20di%20grafici%20-%20Stato%20modificato%20in%3A%20Archiviato%20-%20Duplicato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-244754%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EQuesto%20%C3%A8%20un%20duplicato%20di%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FRight-click-to-change-Group-font-and-font-size%2Fm-p%2F116638%23U116638%22%20class%3D%22lia-mention-container-editor-message%20lia-img-icon-idea-thread%20lia-fa-icon%20lia-fa-idea%20lia-fa-thread%20lia-fa%22%20target%3D%22_blank%22%3E%20Fare%20clic%20con%20il%20pulsante%20destro%20del%20mouse%20per%20modificare%20il%20carattere%20del%20gruppo%20e%20la%20dimensione%20del%20carattere%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-233777%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Cambia%20carattere%20(dimensione)%20sul%20raggruppamento%20delle%20variabili%20nel%20generatore%20di%20grafici%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-233777%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHo%20avuto%20le%20stesse%20difficolt%C3%A0%20con%20Group%20Fonts%20in%20Graph%20Builder.%20La%20soluzione%20migliore%20per%20me%20%C3%A8%3CSPAN%3E%20CTRL%20SHIFT%20%2B%20per%20ingrandire%20tutto%20in%20JMP%2C%20copia%2Fincolla%2C%20poi%20rimpicciolisci%20tutto%20con%20CTRL%20SHIFT%20-.%20Funziona%20su%20Windows%2C%20non%20sono%20sicuro%20per%20Mac.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIl%20seguente%20desiderio%20va%20in%20una%20direzione%20simile%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FFont-Table-in-Graph-Builder-to-quickly-change-Font-settings-for%2Fidi-p%2F51365%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Wish-List%2FFont-Table-in-Graph-Builder-to-quickly-change-Font-settings-for%2Fidi-p%2F51365%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
Change Font (Size) on grouping variables in graph builder
In the graph builder, when using a grouping variable, the Font Size of the label can't be changed easily. The only method I found is to change the general "text" font size in the Preferences menu. This is impractical for 2 reasons :
- it changes the settings on the whole software so it can't be done graph by graph
-  as the "text" font size is very general, it applies to A LOT of items in the software. If you have ever tried changing it, it messes up all your windows, graphs, etc, making them unusable.
So, I would like to request this to be changeable, just like for the X and Y axes. While we're at it, have the same label options as for the other axes, like orientation, etc.
3 Comments
gerd
Level V
I've had the same difficulties with Group Fonts in Graph Builder. The best workaround for me is CTRL SHIFT + to enlarge everything in JMP, copy/paste, then reduce everything again with CTRL SHIFT -. Works on windows, not sure for Mac.
The following wish goes in a similar direction:
https://community.jmp.com/t5/JMP-Wish-List/Font-Table-in-Graph-Builder-to-quickly-change-Font-settin...
Jeff_Perkinson
Community Manager
Status changed to: Archived - Duplicate
Ryan_Gilmore
Community Manager
Status changed to: Duplicate
