  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Allow multiple window splits in the script editor
In the script editor, I would like to have the ability split the window so that I can see 3 or more sections of my code at once.  That is, when right-clicking on the line numbers on the left of the script editor and selecting "Split", I would like the option to specify how many splits I would like to have.
Often I find myself needing to compare 3 or more sections of code to each other.  Adding this feature would make this task much simpler.  I would hope implementing this would be relatively easy.
1 Comment
SamGardner
Level VII
Thank you for the suggestion.  We only have the ability for one split in the script editor currently, and we may take this under consideration for a future release.
