%3CLINGO-SUB%20id%3D%22lingo-sub-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EPermitir%20m%C3%BAltiples%20divisiones%20de%20ventanas%20en%20el%20editor%20de%20scripts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EEn%20el%20editor%20de%20scripts%2C%20me%20gustar%C3%ADa%20tener%20la%20posibilidad%20de%20dividir%20la%20ventana%20para%20poder%20ver%203%20o%20m%C3%A1s%20secciones%20de%20mi%20c%C3%B3digo%20a%20la%20vez.%20Es%20decir%2C%20al%20hacer%20clic%20derecho%20en%20los%20n%C3%BAmeros%20de%20l%C3%ADnea%20a%20la%20izquierda%20del%20editor%20de%20scripts%20y%20seleccionar%20%22Dividir%22%2C%20me%20gustar%C3%ADa%20tener%20la%20opci%C3%B3n%20de%20especificar%20cu%C3%A1ntas%20divisiones%20me%20gustar%C3%ADa%20tener.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EA%20menudo%20necesito%20comparar%20tres%20o%20m%C3%A1s%20secciones%20de%20c%C3%B3digo%20entre%20s%C3%AD.%20Agregar%20esta%20funci%C3%B3n%20simplificar%C3%ADa%20mucho%20esta%20tarea.%20Espero%20que%20implementarla%20sea%20relativamente%20f%C3%A1cil.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatizaci%C3%B3n%20y%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Permitir%20divisiones%20de%20ventanas%20m%C3%BAltiples%20en%20el%20editor%20de%20scripts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGracias%20por%20la%20sugerencia.%20Actualmente%2C%20solo%20tenemos%20la%20posibilidad%20de%20dividir%20una%20partida%20en%20el%20editor%20de%20scripts%20y%20es%20posible%20que%20tengamos%20esto%20en%20cuenta%20para%20una%20versi%C3%B3n%20futura.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Allow multiple window splits in the script editor
In the script editor, I would like to have the ability split the window so that I can see 3 or more sections of my code at once.  That is, when right-clicking on the line numbers on the left of the script editor and selecting "Split", I would like the option to specify how many splits I would like to have.
Often I find myself needing to compare 3 or more sections of code to each other.  Adding this feature would make this task much simpler.  I would hope implementing this would be relatively easy.
1 Comment
SamGardner
Level VII
Thank you for the suggestion.  We only have the ability for one split in the script editor currently, and we may take this under consideration for a future release.
