%3CLINGO-SUB%20id%3D%22lingo-sub-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAutoriser%20plusieurs%20divisions%20de%20fen%C3%AAtres%20dans%20l'%C3%A9diteur%20de%20script%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EDans%20l'%C3%A9diteur%20de%20script%2C%20je%20voudrais%20avoir%20la%20possibilit%C3%A9%20de%20diviser%20la%20fen%C3%AAtre%20afin%20de%20pouvoir%20voir%203%20sections%20ou%20plus%20de%20mon%20code%20%C3%A0%20la%20fois.%20Autrement%20dit%2C%20lorsque%20je%20clique%20avec%20le%20bouton%20droit%20sur%20les%20num%C3%A9ros%20de%20ligne%20%C3%A0%20gauche%20de%20l'%C3%A9diteur%20de%20script%20et%20que%20je%20s%C3%A9lectionne%20%C2%AB%26nbsp%3BDiviser%26nbsp%3B%C2%BB%2C%20je%20voudrais%20avoir%20la%20possibilit%C3%A9%20de%20sp%C3%A9cifier%20le%20nombre%20de%20divisions%20que%20je%20souhaite%20avoir.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EIl%20m'arrive%20souvent%20de%20devoir%20comparer%203%20sections%20de%20code%20ou%20plus%20entre%20elles.%20L'ajout%20de%20cette%20fonctionnalit%C3%A9%20simplifierait%20grandement%20cette%20t%C3%A2che.%20J'esp%C3%A8re%20que%20sa%20mise%20en%20%C5%93uvre%20sera%20relativement%20facile.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatisation%20et%20scripts%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Autoriser%20plusieurs%20divisions%20de%20fen%C3%AAtres%20dans%20l'%C3%A9diteur%20de%20script%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMerci%20pour%20la%20suggestion.%20Nous%20n'avons%20actuellement%20la%20possibilit%C3%A9%20de%20r%C3%A9aliser%20qu'un%20seul%20fractionnement%20dans%20l'%C3%A9diteur%20de%20script%2C%20et%20nous%20pourrions%20prendre%20cela%20en%20consid%C3%A9ration%20pour%20une%20future%20version.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Allow multiple window splits in the script editor
In the script editor, I would like to have the ability split the window so that I can see 3 or more sections of my code at once.  That is, when right-clicking on the line numbers on the left of the script editor and selecting "Split", I would like the option to specify how many splits I would like to have.
Often I find myself needing to compare 3 or more sections of code to each other.  Adding this feature would make this task much simpler.  I would hope implementing this would be relatively easy.
1 Comment
SamGardner
Level VII
Thank you for the suggestion.  We only have the ability for one split in the script editor currently, and we may take this under consideration for a future release.
