%3CLINGO-SUB%20id%3D%22lingo-sub-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EConsenti%20la%20suddivisione%20di%20pi%C3%B9%20finestre%20nell'editor%20di%20script%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ENell'editor%20di%20script%2C%20vorrei%20avere%20la%20possibilit%C3%A0%20di%20dividere%20la%20finestra%20in%20modo%20da%20poter%20vedere%203%20o%20pi%C3%B9%20sezioni%20del%20mio%20codice%20contemporaneamente.%20Cio%C3%A8%2C%20quando%20clicco%20con%20il%20tasto%20destro%20sui%20numeri%20di%20riga%20a%20sinistra%20dell'editor%20di%20script%20e%20seleziono%20%22Dividi%22%2C%20vorrei%20avere%20l'opzione%20di%20specificare%20quante%20divisioni%20vorrei%20avere.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ESpesso%20mi%20ritrovo%20a%20dover%20confrontare%203%20o%20pi%C3%B9%20sezioni%20di%20codice%20tra%20loro.%20Aggiungere%20questa%20funzionalit%C3%A0%20renderebbe%20questo%20compito%20molto%20pi%C3%B9%20semplice.%20Spero%20che%20implementarlo%20sia%20relativamente%20facile.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-504386%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomazione%20e%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Consentire%20pi%C3%B9%20divisioni%20di%20finestre%20nell'editor%20di%20script%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-509985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGrazie%20per%20il%20suggerimento.%20Attualmente%20abbiamo%20la%20possibilit%C3%A0%20di%20una%20sola%20divisione%20nell'editor%20di%20script%20e%20potremmo%20prendere%20in%20considerazione%20questa%20possibilit%C3%A0%20per%20una%20versione%20futura.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Allow multiple window splits in the script editor
In the script editor, I would like to have the ability split the window so that I can see 3 or more sections of my code at once.  That is, when right-clicking on the line numbers on the left of the script editor and selecting "Split", I would like the option to specify how many splits I would like to have.
Often I find myself needing to compare 3 or more sections of code to each other.  Adding this feature would make this task much simpler.  I would hope implementing this would be relatively easy.
1 Comment
SamGardner
Level VII
Thank you for the suggestion.  We only have the ability for one split in the script editor currently, and we may take this under consideration for a future release.
